This may be a dumb question, but did you install ES File Explorer on your S2?
Sorry, but I still don't know what "just backed up" means. You used ES File Explorer to copy the database to a folder? Or did you use its App Manager to backup the messaging app? Or something else?I just backed up everything using ES and they are there in a folder called SMS backup
