Restoring Paid for Apps
DABenji
I am thinking of upgrading to 2.2 but not sure about restoring apps, I was going to make a list of what I have and fresh install them all, but two I have are paid for Launcher Pro Plus and Torque, how do I go about reinstalling them if they are paid for?
I know its abit of a noob question but never had to do it so dont wanna upgrade until I know what will happen.
u must be having .apk file for ur apps just copy them to ur pc.And when u r done with ur 2.2 ROM copy them back to ur sd card.
Hope this helps...!!
Regards
Regards
This would work (and would likely be what I would go with) and is probably easier than making up the list but even if you have to reinstall the apps, the record of payment is still on the Google servers so you wouldn't have to pay for them again.
I use AppSaver to backup all my programs. It will make .APK files of any installed app on the phone, i used it again and again and never had issues with it.
only downside is that this app is real ugly design...but it works
