Restoring with MyBackUp Pro
redsox985
So I backed up my DX entirely (to SD) with MyBackUp Pro just before I activated my D3. I got in to MBUP on the D3 and try to restore from my SD card, it says that no backups were found at the current backup location path, which is /mnt/sdcard.
Do I need to change this since the D3 has it's internal memory as well as my SD card? Does it need a different path?
EDIT: Would a Mod mind erasing this thread. I had to change the path to /mnt/sdcard-ext and then all was well. I guess you could keep it around since I won't be the last with this issue, but it was easily resolved.
in the app hit your menu button, go to options, and click at the top where it says backup location and type in /sdcard/
that should fix it! i got a new phone today and was having the same problem:)
