SavageRobot
Android Expert
Hello guys,
Well I finally bit the bullet being sick of the pretty lazy official update for sgs2 and decided to have a crack at rooting the phone and try out a custom ROM. All was going well...too well. I followed the following "how to" to the T and it worked perfectly...
http://forum.xda-developers.com/showthread.php?t=1501719
After this I flashed the following ROM and it is on there fine.
Resurrection ICS ROM v.2.5.3 for Galaxy S2 i9100! [Jelly Bean Transitions][Best ROM] | Galaxy S2 Root
I really like it and have found no problems but one, a pretty big one for me living in the sticks with bad reception. The WiFi doesn't work and when I press it to turn on it stays stuck at "Turning Wi-Fi on...".
Any ideas what this could be? I think looking at other custom ROM errors on the net that it could be the Kernel? The rooting process I did means that I don't have to put on fake kernel which I thought was a win-win. My kernel after the flash I think is about the same, the letters in the middle are anyway (BVLPB) but then it has some other stuff after what the original one was (SMP PREEMPT Wed Apr 4 23:23:21 KST 2012). Is this something to do with it? If so any ideas on a fix? If not any ideas what else it could be?
I factory reset and wiped cache/davlik cache and re-flashed the ROM through CWM again but didn't work.
Thanks in advance guys...
