retreiving texts
sniper8752
I installed a new rom on my phone. there are no texts from previously. is there any way that I can get them back?
It's not quite that simple. It's stored in data/data/com.Android.providers.telephony/databases/
It's called mmssms.db
It's sqlite format.
it's a database file and the texts are 'built' from it
Just make a nand of this rom, restore the old one's nand
Backup the files with the app i linked, and restore the nand for your current rom. Then just restore them
Yes
1.back up current rom
2.restore previous rom (via cwm/whatever you created the backup with)
3.backup texts with aforementioned app
4.restore current rom (via cwm/whatever you used to create the backup)
5.reinstall aforementioned app
6.use restore feature in app
7.press thanks button :D
Yes, but i have not found a way to make the system build the texts...
Honestly, all the time you spent questioning this simple solution, you could have done it several times by now...... ;)
