return key saved in file name with root explorer. PLEASE HELP!!!
IYIaster
I was moving some files around trying to get a custom boot animation to work. In /system/bin I had put a custom bootanimation file and renamed the other to bootanimation.old. Some how I had put a return key in between bootanimation and old instead of the dot. So I have a file name bootanimation(returnkey)old saved. Root explorer thinks the filename is bootanimation now and when trying to do anything (delete, move, rename) it says it goes through but when I leave the directory and go back in it didn't. I tried deleting it from the console, but that didn't work either. Any help would be appreciated.
OK... Anyone know an Droid forum that isn't dead?
