Root Return to ice cream to reinstall jellybean
TexasTuff
Member
Trying to go back to ice cream so i can install jellybean using cmw cause it seems there are less problems then the legit way.
There is no need to go back to ics. Just install cwm and flash a b11 rom. If you are not on b11 now, you will need to flash the System Prep JB before flashing the rom.
Im on b11 right now so i just install cmw then flash b11 rom and i can do it without root
Ok i seen alot of roms But im confused a little on them someone please post some links to stock b11 and juckie tools
Both tools will work if you are just hooked up and booted into your rom. They will put you in the correct mode. Make sure you have USB debugging enabled.
Ok im on it now..... i see why juckies aio tool wasn't working it was discontinued only the c+++ edition works
Yep juckies tool aint work i checked drivers and ive done it before but it wont install cmw on my phone and people say i dont have to be rooted so im try yours but i dont have fast internet so im have to wait till tomorrow and ill let you know
Perhaps you should read the stock b11 thread
Im running your superb11 and i have to say i love it and thanks for all the help superR you have made my phne the fastest its been. Thanks......one ? Is there a ay to get boost zone back if not i can live without it
There is a zip file at the bottom of the stock b11 thread that contains deodexed versions of all the removed apps. Boost Zone is in that zip. Feel free to grab whatever you like ;)
So meaning i have to use a computer cause i was using my phone
SuperROM has ES File Explorer...it will extract zips. I think the main problem is that you still haven't read to the bottom of the stock b11 post and found the zip. I think you are looking at the list of removed apps instead.
Yep im a dummy i was looking at the list i got it now that superR o nice rom
How do you tell if you on b09 or b11? I'm running awesome Android 4.
