[Review] Seidio Active Combo
howetechnical
If you
Thanks for the review. Is the Active case difficult to put on and remove from the phone? I have a couple of spare batteries with a stand alone wall charger, and like swap out batteries instead of plugging it into the wall. I like the sounds of this case, but am concerned that this could be an obstacle, since I need to change batteries without a major ordeal.
Takes only a few seconds to take the case off, and about 10 seconds to put it back on. You should be fine.
I received mine a few days ago. Really like it. It feels really nice in the hand, fits well, much thinner than i expected, and really just looks nice.
I have received mine as well now. As others have said, it is not bulky, and goes on and off pretty easily. I am very pleased with the holster combo too, though I do wish that the belt clip rotated 360 degrees, rather than 180. Not a big deal, but mildly annoying.
