MiXoLoGiSt
Today i am reviewing the Seidio Innocase Active.
The case has Seidio's Soft Touch feel to it which makes it very nice and adds a bit of comfort when it comes to grip. The case consists of two layers, The first layer is a silicone layer and the second layer is a hard shell that goes over the silicone. This combination of layers will provide good protection from drops and scratches because it will be able to take shock and at the same time will be strong enough that it wont budge. The power button and volume up and down rocker are covered by silicone as well and the silicone over these buttons is solid so that you can still easily push the buttons with the added thickness of the case. The case is very easy to install and remove. It does add a little bit more bulk than the Seidio Innocase II Surface but also adds more protection. It actually feels very nice in my hand. It will easily slide in and out of your pocket if thats where you choose to keep your phone. The case provides protection for the protruding camera on the back of the Incredible. This case will sit a little higher than the camera so the camera isn't sticking out anymore. The cutouts for the Camera, 3.5mm jack, Back Speaker, Charge Port, and microphone were all cut very nicely and with precision. There is also a cutout around the front speaker so you can still hear the person you are talking to loud and clear. The sound quality from the back speaker is not affected with this case installed, and call quality was not affected while on speaker either. Picture quality was also still at its best with the case installed.
Overall i think this case is very nice. Your phone will be protected while still having tons of style and protection. Another great accessory by Seidio!
