I've read in several threads that in case someone keeps the stock Rom after using Revolutionary (with the cwr installation) and rooting, there is the need to flash the original recovery too (to avoid problems in case of OTA updates)
I'm still using the 1.13.605.7 because I'd like to keep using the video capability of the front camera in Skype (I'm using a old leaked version that is not working with the updates) and in the past weeks I've noticed several attempts of updates to MR2 that I promptly stopped.
Is there any way to stop the OTA push on stock roms? is it possible to do that by editing the build.prop file? (even though that might be a temporary solution until next OTA) if so, how should I edit the "fingerprint"?
Since I made a Nandroid backup with the crw installed by Revolutionary, if I flash the stock MR1 recovery as suggested, I guess I won't be able to restore it. To be able to restore it do I have to flash back on the phone a specific CWR version (like the Revolutionary CWR 4.0.1.4, of which I couldn't find a PG05IMG file but just the .img) or any CWR would work?
Thanks in advance for the help
