With the recent reports about cell phone radiation, I'm trying to figure out the SAR values for the Motorola/Verizon device. It's a shame it's so hard to get this information and that the FCC doesn't require manufacturers to publish this information for the consumer to easily read.
Anyway the first thing you need to find it is the FFCID so that you can do a search on the <sarcasm> always user friendly </sarcasm> FCC Web search page. I've seen 2 FCCIDs (IHDP56KC2 and IHDP56KC5) for 2 Motorola phones that are likely Droids but not necessarily the one that Verizon is releasing next week. After digging through the FCC documents for those devices I found the following...
IHDP56KC2: SAR 0.57 W/kg for head-adjacent use and 0.49 W/kg for body-worn use
IHDP56KC5: SAR 1.10 W/kg for head-adjacent use and 0.89 W/kg for body-worn use
This question is, is either of these the Verizon Droid that ships on November 6th? Perhaps someone with a review unit can check on FCCID on the device to verify?
FCC Search page (requires device FCCID)
FCC's page to manufacturers SAR info (essentially worthless)
- Cliff
- Cliff
