Right place ?
davidtxs
ok just gpt a galaxy lll and in search for a better choice of ringtones. I downloaded some from the google store they show up under downloaded apps. but when I go into settings and ringtone section they arent to be found any idea ???
Thanks
I had the same problem with my S2. It downloaded them to the SD card but the Settings couldn't find them. I finally moved them and then it worked. Can't remember exactly how I did it, though. Sorry.
What might have to do is go to your app drawer and open up My Files. Create a folder in the Media file and name it Notifications and save it. Stay in My Files and find the folder with the MP3'S. Long press on a song and select copy, then go back to Notifications folder and put it in there. Now, back out to home screen and, I think its, Menu: Settings: Sounds or Default Notifications and see if the mp3 is in there with your other notifications. (Something like that) I don't have that phone but it should be similar.
