Help Right side of screen color issues
Spida90
I think the pics explain what my issues are. I've tried rebooting and restoring to stock, but nothing. I just hit the left button to turn on the phone, and noticed the screen was messed up. I haven't flashed anything since the first week of November, so I don't know whats wrong. Any suggestions? Send, it to virgin maybe?
Edit: Im running miui 11-4 build.
Looks like your LCD is dead... It may just be a problem with the screen's ribbon cable or it could be the LCD... there's no bleeding so my guess would be the ribbon cable. Its probably fairley easy to fix but it could be a bigger problem... I would flash astock nandroud backup and stock recovery and get a replacement from vm.
Thanks for the quick responses guys. So, I should just call them up and tell them basically that the right side of the screen is gone. Also. Im now 100% stock.
Yeah, call them and just tell them what is going on, they will probably have you try a few things and then send a replacement. Unless they can help you fix it without that.
