cheattowin1
Is there a way to make songs downloaded from rapsody into a ring tone?
).If you can download to the computer, you can use Audacity (free) Saves in many formats and you can cut and edit.
I use MID format. Harder to edit. But very tiny files. A 4 minute song might only be 17k, and the phone will play all of it.
Hello cheattowin.
The method of making ringtones from downloaded music depends on a few things, especially the version of Android OS you're using (and the phone, of course).
If the music is in mp3 file format, it may just be a matter of long pressing the file, or hitting the menu button with the file on the screen, and making the right selection in that menu.
I see that you posted a question about rooting in the LG Esteem forum; do you have a rooted LG Esteem?
