ring tones
CWCIII
I'm new, and an old fart, how do you download a ring tone from my computer and how do you select the file?
Thanks
I just did the same via USB.
First you need to ensure the file is in MP3 format.
Plug in your phone and connect to your computer> select "Mount as Disk drive" from the menu that pops up> open the new drive (mine is called No Name) on your computer to see the contents of your SD card> from here you can copy and paste the file you wish to use as your ringtone from your computer to the SD card.
Gerenmoor suggested a great way to put all ringtones, alarms etc together in the one folder in this thread and works perfectly:
http://androidforums.com/htc-desire/59664-htc-desire-tips-tricks-read-me-4.html#post977316
