Help ringback and memory
How do I get ring back tones with out going Thur tone room deluxe? ?? And is there away to put apps whether free or paid on to ur SD card. Phone memory sucks
I don't know the answer to your first question as I have never set that up.
In answer to your second question you can move apps to the SD card but that app has to be designed to do that. Some apps can be moved and others can't. The way to find out if you can move them to your SD card is to go into the phone settings and check.
To do this start from your homescreen and click the menu button on the phone. Next select settings. Then select Applications. From there select Manage Applications. This will list all of the applications on your phone. From here select the app you want to try and move to the SD card. The applications options will show up. One of the options is Move to SD card. If this option isn't greyed out then you can move the app to the SD card.
I am assuming you are running Android 2.2. If not the instructions above may not work.
Hope that helps.
Ringback tones are on your account, not your phone, so there is no other way that I am aware of other than TRD.
As for moving apps to the micro SD memory card, if you have upgraded to Froyo (Android 2.2) and the application is written for it, this should be no problem.
