ringer question
trach
is there a way to modify the ringers that come stock with android? for instance, if i select the ringtone "standard 4", it sounds like a very basic ring.. but when you actually use it he pause between rings is ridiculously short and just makes the ringer completely obnoxious. is there a way to set how long the pause between rings is? if not, whats the best place to find a good basic/office type ringer?
thanks!
There's app called "ringdroid" you can use it to modify ring tones. You can take music files that you have and modify them to use them as a ring tone. I haven't tried to see if I can modify ring tones that come standard on the phone tho.
cool thanks!
