Ringtone and Earpiece volume too low?
Yep, same here, went from Nokia N97 to N900 (which were great) to X10 and the earpiece volume is well sub-standard, very hard to hear the conversation if I'm in the street.
Don't know about firmware update, when I connect to SE Companion it says I'm up to date (only had it a week).
I have a same problem, i bought x10 (new) in bosnia and herzegovina, ringer volume and earphone is very, very low at max. I wrote about that to SE but they tell me there is no solution for this problem... anyone have solution... i'm runnin lastest update... thanks
Here is what thay told me:
Sony Ericsson
X10 has a lower volume in the ear speaker compared with other phone models, but if you find the ear speaker volume to be significantly low I suggest that you contact your retailer to check if it might be some problem with your phone.
-Johan
