Ringtone duration
  • Start date Start date
A
Android Question
Guest
How do I change the length of time the phone rings before it transfers to voicemail
Hi
Sadly this is a parameter fixed by your carrier and not by your phone settings. You could try asking them but I dont think you will get anywhere..
Roger
Hi, girolez is quite right, it is a network setting, not a phone setting. However most carriers allow the phone user to change it by keying in an MMI code but as is so often the case different carriers have different access numbers.
For Orange (UK) it is **61*07973100123*11*xx# (*61*07973100123*11*xx# also works)
where xx is time in seconds, 05 up to 30 in 5 second steps. I have changed mine so I know it works.
If you Google search :-
"Changing number of rings before voicemail on xxxxxx"
where xxxxxx is your carrier, you should get the appropriate info.
Hope this helps. :)
