ringtone heard through bluetooth headset
Jmaes
Hello,
iam using a Samsung galaxy s6 edge.... looking for a bluetooth headset that would be able to play the incoming call ringtone of the phone when i have an incoming call....
any suggestions?
James
Just about any Bluetooth Headphones should be able to do that for you Jmaes. I'm using Photive BTH3 Bluetooth 4.0 Headphones with Built-in Mic and 12 Hour Battery currently. But I've also used Rocketfish™ Mobile - RF-MAB2 High-Definition Stereo Bluetooth Headphones with both Samsung and HTC products with good results. The Rocketfish model has since been discontinued but the Photive BTH3 is still available at Amazon.
I know the lg ones do! I had issues hearing BC I never kept my ear plugs in unless I was on a call so I turned that feature off! But most should have that feature
hello.... and thanks for your response..... i am actually looking for headsets like voyager legend .... the ones that are used for calls.... i actually have a voyager legend already... but somehow after a week of using it the caller ringtone could no longer be heard through the headset when i have an incoming call..... it USED TO play the ringtone first few days i got it.... dont know what happened now....
hi DPB...... yeah already did the headset updater thing.... still the same....i get everything on the headset/.... stream audio message notification sounds everything.... EXCEPT for incoming call ringtone......;(
