Ringtone Resets for S Planner
  • Start date Start date
D
Deleted User
Guest
I have a Samsung Galaxy S4 and I use S Planner for recording tasks (with reminder ringtones)
If I go to Settings and set a specific ringtone (one which I imported) the ringtone works fine whenever a task becomes due.
However, if I restart the phone, the alert ringtone reverts to the standard "On Time" ringtone.
T
1. Do you happen to know there file format of the ringtone? If so, what is it?
2. How are you applying the ringtone? Through the settings of the app, or through the phone's settings?
The format is MP3
The selection of ringtone is done in the app settings
You might want to try the S4 Forums then, as that's a Samsung app that sounds like it's misbehaving
If you hit the report button in your initial post, and state which S4 you're having, you can request for a move of this thread. Cheers!
