if you download the app WhoIsIt Lite (free) you can. It works great, was suggested to me by my cellphone rep. Just remember to silence ur phone notifications otherwise you will get double tones. Also.. there is a setting that u must select that the tone will stop once u touch ur screen.. otherwise it just plays until the tone is done. If you download the app.. when u go into it hit ur menu, prefereces and scroll down and check the box that says tap screen to silence.
