Ripple Lock v2.3.5
SOLA
Are you still envy of the brilliant lock screen of Android 3.0? Now, as long as your phone is Android system, you will be able to experience the beauty of the lock screen. Only use one button, you can choose to use this ripple lock screen or system default screen.
Drag the inside circle to the outside circle can unlock screen.
the market link:
https://market.android.com/details?id=com.nanoha.MyLockScreen_free&feature=search_result
hope you will like it~~~:)
  • RippleLock_wp.apk
    RippleLock_wp.apk
Version 2.3.5
1.Add "Use answer call button" setting item. If you do not want to use lockscreen answer and hang up call buttons, please disable this setting item.
2.Fix the problem of zoom in and zoom out widget function.
Version 2.3
PS:If you meet problem , please email to me and give me some time, I will fix the problem as soon as possible.Every week I will upload new version.
If you have a double lock-screen problems,or home button problem, or the volume keys light up the screen, try using the "fix double lock issue" setting item.
1.New feature: Users can choose their own font file.
2.New feature: During add widget, add zoom in and zoom out function.
3.New feature: When call is ringing, you can select answer or hang up this call in lockscreen. (Part of the phone, answering call function is unavailable)
4.fixed the lockscreen wallpaper problem.
5.Fixed FC problem during add widget.
