[OFF TOPIC] saw your name in one of the boards and just dropped by to say hi and long time no see.
How's it going? Cheers!
Sent using the force
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IML77
ro.build.display.id=IML77
ro.build.version.incremental=release.20120629.183038
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.4
ro.build.date=Fri Jun 29 18:31:08 JST 2012
ro.build.date.utc=1340962268
ro.build.type=user
ro.build.user=release
ro.build.host=release
ro.build.tags=release-keys
ro.product.model=C5155
ro.product.brand=kyocera
ro.product.name=C5155
ro.product.device=C5155
ro.product.board=C5155
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=kyocera
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=msm7630_surf
# ro.build.product is obsolete; use ro.product.device
ro.build.product=C5155
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=C5155-user 4.0.4 IML77 release.20120629.183038 release-keys
ro.build.fingerprint=kyocera/C5155/C5155:4.0.4/IML77/release.20120629.183038:user/release-keys
ro.build.characteristics=default
ro.build.internalswversion=1.000VM.05.a
ro.build.swversion=1.000VM
# end build properties
# system.prop for surf
rild.libpath=/system/lib/libril-qc-qmi-1.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV
DEVICE_PROVISIONED=1
debug.sf.hw=1
dalvik.vm.heapsize=24m
dev.pm.dyn_samplingrate=1
# system props for the cne module
persist.cne.UseCne=vendor
persist.cne.UseSwim=false
persist.cne.bat.range.low.med=30
persist.cne.bat.range.med.high=60
persist.cne.loc.policy.op=/system/etc/OperatorPolicy.xml
persist.cne.loc.policy.user=/system/etc/UserPolicy.xml
persist.cne.bwbased.rat.sel=false
persist.cne.snsr.based.rat.mgt=false
persist.cne.bat.based.rat.mgt=false
persist.cne.rat.acq.time.out=30000
persist.cne.rat.acq.retry.tout=0
persist.cne.sync.swim.mode=false
lpa.decode=true
ro.hdmi.enable=true
# system props for the data modules
ro.use_data_netmgrd=true
# system props for SD card emulation of emmc partition
ro.emmc.sdcard.partition=16
# system props for telephony modules
#device supports EHRPD
ro.config.ehrpd=false
# system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-meta=false
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
media.stagefright.enable-fma2dp=true
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
lpa.use-stagefright=true
# system prop for opengles version
ro.opengles.version=131072
# system prop for Bluetooth Dialup Networking
ro.qualcomm.bluetooth.dun=false
# system prop for Bluetooth Auto connect for remote initated connections
ro.bluetooth.remote.autoconnect=true
# System prop to disable strict mode flash on display
persist.sys.strictmode.visual=false
# system prop for multi rild (DSDS case)
ro.multi.rild=false
# system prop for Bluetooth FTP profile
ro.qualcomm.bluetooth.ftp=false
# system property for Bluetooth discoverability time out in seconds
# 0: Always discoverable
#debug.bt.discoverable_time=0
# system prop for requesting Master role in incoming Bluetooth connection.
ro.bluetooth.request.master=true
# system property to enforce Phone Mode view
ro.screen.layout=normal
#System prop for disabling the meta data mode for encoder
debug.camcorder.disablemeta=0
# Simulate sdcard on /data/media
persist.fuse_sdcard=false
# Turn off tiled rendering
debug.enabletr=false
# System prop for using landscape preview layout in camera
debug.camera.landscape=true
# System prop for capping scroll velocity
ro.max.fling_velocity=4000
# System prop for max evnet per sec
windowsmgr.max_events_per_sec=60
# System prop for Chameleon
ro.com.google.clientidbase=android-kyocera
ro.com.google.clientidbase.ms=android-virgin-us
ro.com.google.clientidbase.yt=android-virgin-us
ro.com.google.clientidbase.am=android-virgin-us
ro.com.google.clientidbase.gmm=android-kyocera
ro.cdma.home.operator.alpha=Virgin Mobile
ro.cdma.home.operator.numeric=311490
# ADDITIONAL_BUILD_PROPERTIES
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=36m
dalvik.vm.heapsize=128m
keyguard.no_require_sim=true
ro.com.android.dataroaming=false
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=CurveBall.ogg
ro.config.notification_sound=DontPanic.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.vendor.extension_library=/system/lib/libqc-opt.so
ro.setupwizard.mode=DISABLED
ro.com.google.gmsversion=4.0_r2
drm.service.enable=true
ro.camera.sound.forced=1
drm.service.enabled=true
persist.sys.ringermode=2
persist.timed.enable=true
persist.sys.language=en
persist.sys.country=US
browser.management=false
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
