I have to travel across the US and i tried to update my roaming list, so i dialed *228.
It's asking to activate my phone....
How can i update my roaming list?
Thx
The ROM is ok its the stock Dailer App that you want to use. If you have not dwnloaded a replacement app then you are using the stock dailer. So in short, if you have more then 1 app that can access you phone dail pad try them allI'm using #2 v1.4
Thx all...it worked
But MtroPCS outside FL sucks!...i need to find another carrier
