Root roaming?
fcortes626
i am running lezo os cm7 based rom. i have data roaming off and i have a triangle instead of the 3g icon
I've had the same issue when on cm7. I know boost doesn't have roaming so when that symbol comes up, it's like having no signal (at least from my experience)
Noitced I was roaming for a moment while using the 61008 PRL on CTMod 3.4 so its possible to receive roaming on an official prl.
did any of you guys check your channel/SID to see if you were actually roaming or if it just said you were?
I have had the message pop up when I was actually roaming, and also had it pop up and lose my data when I wasnt roaming, but could still make calls/txt.
