Help Robo defense problems
Lately, every time I try to play my favorite game on my Incredible (robo defense free version) the screen is locked in one place.
This is very difficult to explain without screenshots so please forgive me while I try to describe the issue in a way which is easy to understand.
Normally you can slide to the right and see the exit point of the map as well as up and down. My screen is locked so that I cant even see the exit point.
Also, the attackers don't even come out of the normal entry gap, they come out of the trees, making it difficult to know where to place the towers.
I have un-installed and re-installed the game, with no solution to the problem.
I am not sure if another app is the cause of the glitch, but I decided to check here to see if anyone else has had a similar issue before I contacted the developer.
Thanks
Ive played the game for almost a year now. Never seen that issue.
I would definitely contact the dev.
