Hi there i use both Insyncr and Rocket Player from JRTStudios and i believe as of this last update every time i click the next song button the song starts playing at max volume until i hit the volume key up or down then it returns to where it was previously. It stays at the same volume if i just let the song run over into the next one but if i ever want to skip the song i have to deal with the sudden blaring of music into my headphones. I have already uninstalled reinstalled and tried removing every file related to it. Anyone else? I appreciate any help you can give and if it helps use i have a Droid RAZR M. Thanks
Edit: thanks to cyndies post I found that smart actions does stop the music from going back to high so an easy fix is to just use the workout sample then add the action adjust volume to whatever you can still change the volume as you see fit and it won't go back to max afterwards. Thanks cyndie!
