Help roger released 1.6
nsheff64
Rogers just released 1.6 a couple of days ago through the lg updater program but 'google search by voice' still does not recognize the update. Is this necessary for using a bluetooth voice dialing headset I don't want to buy a bluetooth headset if I can't use it.:confused:
Thanks
Did you actually get 1.6 on the eve? I followed Rogers instructions and used the LG updater thing, it did the update but it only updated the firmware not the OS.
Have you had any trouble getting apps? I went to the Marketplace and every one I tried getting said "Download was unsuccessful"
Yes apparently there is a problem with the new market app. Its has to be synced properly with the gmail account. You have to go to settings - applications - manage applications - market - uninstall updates and clear cache. The first time I did this it did not work then I went to the market on my computer and logged in with my gmail account and had to confirm a licence agreement then went back and cleared the updates and cache again and it worked fine
the only thing i see is software update to 10Q when i connect with the lg mobile update, will it want to do the firmware update (1.6) after that ?
10Q is 1.6. I did the update an oh my god what a difference.
Google quick search box, new market..
If you want to be sure go into your settings and "About phone" you will see the firmware version is 1.6
just did 1.6 update today, new year/new update i figured.
took approx 15 min to do the update, i see some changes
