Help Rogers magic in continuous reboot
beaker59
I have a ROGERS MAGIC that is in continuous reboot. I Have to take the battery out to get it to power off. I have done a hard reboot but still have the same result. I got tired of waiting for an update from 1.5 from rogers and was using the new cyangon Rom using ROM Manager. Any help would be greatly appreciated.
yes... I got it working by letting reboot
connecting it to pc as windows 7 kept detecting it
ran the rogers update and was lucky enough that the update caught it in the reboot and put it in fastboot/hboot mode.
if you can get to fastboot you are in good shape.
from fastboot... make sure usb is connected
I ran the upgrade downloaded from htc magic rogers support page. went back to normal. worked great for me.
if you are in fast boot, then there are many things that you can also do. check the xda forums. pretty much you can reload any recovery.
Then I rerooted, changed to an eng SPL. loaded froyorider rom, and now loaded arasense rom. avoided that rom manager completely.
hope it works for you
