Root [ROM] 2.40 R2D2 Removed - Complete & Clean ROMs
MotaBoy
Thanks to My Doid World for releasing the R2-D2 2.40 ROM. It has a few bug fixes besides the Stars Wars additions. All Star Wars related items have been removed and replaced with D2 items. Star Wars sounds have been left in.
Full Version:
Download HERE - Update 1 - Does not need Kill CP30 message contact fix.
All bloatware has been removed. Google Maps, Gmail, Street and Voice Search have been removed and can be updated from Android Market. Google Search has been replaced with latest from Android Market and placed in system/app folder.
This ROM already has root, you just have to download the superuser from market or install from SD Card. All Blur and Blur widgets have been kept in Full Version.
Busybox is installed in xbin.
Install Instructions:
Download MotaBoy_VZW_2.4 ROM from HERE - Update 1 - Does not need Kill CP30 message contact fix.
Place on your SD Card
Boot into Recovery (Must have Droid2 Bootstrap installed)
Mount System
Open Command Prompt on PC do the following commands:
Code:
adb shell
rm /system/app/*.*
rm /system/framework/*.*
Exit
Exit
Wipe Cache
Wipe Data
Double to check to make sure System is Mounted
Install zip from SD Card
Choose zip from SD Card
Select MotaBoy_VZW_2.4.zip
Yes - Install
Reboot and you are all done!
Enjoy!
Super Clean Version:
All Blur widgets have been removed. All third party apps have been removed too (amazon, kindle and so on). There is no Gmail app since new version is in market and no Email or Corporate apps either. Just dialer and contacts are what remains from Blur. Voice Search is removed too but Google Quick Search Box is in app folder so browser search functions properly. Text message, Calendar, Clock and Gallery are from vanila Android. Themed Droid2 Launcherpro is included. This is a clean system with Black Status (HTC) bar added. If you need other packages you can grab them out of the Full Version.
Install Insctructions:
I am going to guess you are already rooted and have ADB installed since you need to be rooted to install this ROM.
You must have installed the full version first.
Download my app and framework files HERE.
Place app and framework folders from archive on the root of your sd card (/sdcard/app /sdcard/framework).
Make sure your phone is plugged into the USB cable and PC Mode is selected and that you have debugging enalbed on the phone application settings.​
Open DOS prompt and type the following commands or paste them at the DOS prompt.​
adb shell
su
stop
mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
rm /system/app/*.*
cp /sdcard/app/* /system/app/
cp /sdcard/framework/* /system/framework/
reboot​
The rm /system/app/*.* & rm /system/framework/*.* will remove all files from your system/app and framework folders. If you have any apps you want saved in your app folder then back them up. The cp commands copy the new files back to your app and framework folder.
Busybox Install:
Connect Phone to PC and place in PC Mode.
Open Command Prompt : Type or paste following commands:
Code:
su
cd system/xbin
busybox --install /system/xbin/
mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
sync
reboot
Will place Themes, Tips & Tricks here.
Market fix on the way for those who need/want their paid apps to show up.
Black Status Bar (HTC) Only for Full ROM
Download from HERE
Place on SD Card
Boot into recovery
Mount system
Install zip file from SD Card
Select MotaBoy_Black_Bar_VZW_2.40.zip
Install and Reboot
Kill CP30 for contact with no picture in message App
Download HERE
Install from Recovery
