Root Rom #2 gives no phone signal
edimmu
Flashed ROM #2 2.5 today along with the LD-ZVD kernel and JellyBean theme. Everything works fine however I'm receiving no MetroPCS signal (it still says "MetroPCS" on lock screen and the 4g LTE symbol on the top)). Internet works fine with wifi and doesn't when turned off.
When I try to place a call I get:
"The process android.process.acore has stopped unexpectedly. Please try again
-My parents are on the same carrier+plan and their phones work fine I just checked-
Just reflash again make sure you do a full wipe, number #2 rom is really really good.
factory reset necessary or just rewipe the kelvin and cache files stuff?
Don't factory reset.. can try just re flashing the Rom first only wiping cache and dalvik.. if that doesn't do it then wipe data and try again.. once again don't factory reset, especially through the phone as it will kill the phone and create a huge hassle..
Sounds like you tried to change the dialers or you replaced something major .....that happened to me but i was trying to change the dialers and thought i hit contacts and the new dialer but hit just the dialer ..
