Root [ROM[25.3.]ParanoidAndroid Blade 3.15+/AOSP 4.2.2 by zeelog
De@n
ParanoidAndroid 3.15 AOSPA 4.2.1 for Zte Blade
MINIMUM Partition: 160MB
Use at your own risk, I'm not responsible for any data loss,etc etc, always TAKE A FULL BACKUP before trying out a new ROM!!​
INSTALLATION INSTRUCTIONS:
Before you begin: This is not an upgrade for previous releases of ParanoidAndroid, I recommend a full wipe before using this ROM.
Download ROM, GAPPS on your SDCARD:
LATEST ROM: http://goo.im/devs/z...2013-124317.zip
GAPPS 4.2: http://www.mediafire...ss5khtjf9a5v4s9 (Thanks to KonstaT)
OFFICIAL PA WALLPAPERS: Goo.im Downloads - Downloading ParanoidWallpapers.apk
Boot into Recovery, Clockwork.
Optionally, but HIGHLY RECOMMENDED: BACKUP YOUR CURRENT ROM
Wipe Data/Factory Reset (Mandatory if you're coming from any other ROM!)
Wipe Cache
Mounts/Storage > Format System (Mandatory if you're coming from any other ROM!)
Advanced > Wipe Dalvik Cache
Install from zip > Select downloaded ROM
Install from zip > Select download GAPPS
Reboot (might take a while,pls be patient!)
If you're coming from the initial release, then it's recommended that you take a backup of your PA Settings,
Download latest version, install ZIP from SDCARD
Install GAPPS from SDCARD
Wipe Dalvik Cache
Reboot
CREDITS:
KonstaT
C3C0
Ganster
Daemond
ParanoidAndroid Team
CM Team
AOSP (Google)
SOURCES: Device Config, Base Rom& here
CHANGELOG:
25/MAR/13
http://goo.im/devs/zeelog/roms/blade/pa_blade-3.15-25MAR2013-124317.zip
Fixes media type issues
(after rom installation + gapps, go in settings > apps > Gallery > clear cache/data)
23/MAR/13
http://goo.im/devs/z...2013-121303.zip
(MIRROR): https://hotfile.com/...121303.zip.html
Replaced FM app with EFFEM (credit daemond,konstat)
Backport Bluetooth UHID driver from linux 3.8 (Credit plaguedbypenguins,konstat)
Added support for various Bluetooth input devices (BT Keyboards/Mice)
Fixed FM audio routing (credit C3C0, konstat)
Added new toggles:
PIE, Volume Control
Fixed 2G/3G toggle
Added CM quiet hours
7/MAR/13
http://goo.im/devs/z...2013-100800.zip
Synced with PA3.1
Added FM Radio + RDS Support (Credit daemond/konstat)
Added launcher settings
Added option to enable/disable H/W acceleration in lockscreen
Integrated SuperSU in settings
AOSP fixed starting windows memory leak
Updated Quick settings + added more tiles
Further PIE enhancements + fixes
28/FEB/13
http://goo.im/devs/z...2013-162918.zip
Libpower tunings
Updated KGSL from CAF, fixed GPU out of memory issues (Credit Daemond)
PIE Enhancements & bug fixes
Added maximize widget option in Lock Screen
Lock Screen bug fixes & enhancements
Fixed keyguard statusbar showing while in ext desktop
Centered accept/reject call button
16/FEB/13
http://goo.im/devs/z...2013-183609.zip
Now based on Android 4.2.2
Added long press home to display recents
12/FEB/13:
http://goo.im/devs/z...2013-123933.zip
Fixed native WiFi tethering
AOSP Keyboard fixes
Added option to disable button backlight (Settings>Display) (Credit to C3C0)
Ported more CM Phone features:
>Flip to mute
>Vibrate on answer
>Vibrate on call waiting
>Vibrate on hang up
>Vibrate per 45secs.
Added new PIE features:
> Repositioning system
> Enhanced animations & snappoints
> Ability to center pie
Surface texture enhancements (Credit daemond)
11/FEB/13
http://goo.im/devs/z...2013-121146.zip
New PA3 Boot Logo
Bluetooth fixes
New HDPI Status bar icons
Added power menu settings
Added settings for low battery warning
Added settings for screenshot
Updated SuperSU
8/FEB/13
http://goo.im/devs/z...2013-103334.zip
Added CM Performance Settings
Fixed FC in AOSP Keyboard
Updated Hybrid properties
- Tools > Expert mode
- Fixes of general layout
Added CM Call Statistics
6/FEB/13
http://goo.im/devs/z...2013-182251.zip
Initial/Preview Release
(See 1st Page for list of known issues)
