Root [ROM][31-01-12]iTimmy-2.1.8 by elizabeth1995 from android indonesia forum
DroidFiesta
I'm not the ROM creator, I just found this rom from Indonesia android forum. Created by a pretty girl named Eliza. Overall, I think its very nice ROM.
This is the original source for this ROM
According to the maker, this ROM base of MiniCM7 by nobodyAtall & DaRk_dOg @xda
Changelog:
iTimmy-2.1.8 base on MiniCM7-2.1.8 (31/01/2012):
Naa only work with kernel version 10 -> download kernel nAa.v10 here
- Update to 2.1.8 MiniCM7-
- A2sd darktremor
- Patch sqlite
- Some MIUI applications, such as MIUI launcher, milocker, miren browser, miui gallery
- Fix installation whatsapp and market (note: install untukk market like usual, download
vending.apk and reinstall)
- Theming on Many diagnostic applications, such as music applications, deskclock, calendar, etc. (orange
taste .. )
- Deodex Framework and SystemUI (so miles can modif view) -> use the UOT
Kitchen modif display according to your taste.
- ITimmy bootanimation and transformers bootsound
bug:
- Center clock is still an error -> disable center clocked at iTimmy Settings -> interface
-> Status bar tweaks -> uncheck center clock
Download ROM here
iTimmy (First Release) base on MiniCM7-2.1.6 (25/01/2012):
- only work on nAa kernel until version 9, download kernel nAa.v9 here
- Update patch for sqlite library (source ungaze @ xda)
- Minor changes to the theme, fonts, wallpapers, bootanimation
- Changes to the lockscreen style -> lense style
- The addition of several applications MIUI -> Miui launcher, Miui gallery, miren browser, milocker, miui music
- Darktremor App2sd include in ROM, so you only need configure via APP2SDGUI
- Wrote a note, after the completion of the installation ROM drive and reboot, the phone will reboot 3 times and
The first boot will take ~ 3 minutes, but after
that there would be no problem anymore. Follow the installation instructions step by step
- Bug fixes for whatsapp application -> just download and install from the market
- Improved market applications -> how to downlod vending.apk here
and install as customarily -> if there is a notification to replace the application
ok wrote on.
- Addition of google maps application
- Addition of transformers bootsound
- Deodex Framework and SystemUI, for ease of customizing -> UOT use of kitchen
- Remove some useless applications
DOWNLOAD here for first release
HOW TO INSTALL (PLEASE READ CAREFULLY!)
ROM installation only uses CWM Recovery
1. Download iTimmy and copy it to / sdcard you -> Download here
2. It is recommended to backup the contents of / your data: contacts, apps, sms, etc.
3. Unlock your bootloader
4. After a successful unlock BL, flash your kernel with Kernel naa v9 or v10, please see the requirements for the ROM
5. If the flashing is complete naa kernel, then reboot and go to cwm
recovery
(Press the back button repeatedly to enter recovery CWM)
- Select 'backup and restore -> Backup' - nandroid backups only for jaga2 aja
- Select 'Mount & Storage -> Format / system'
- Select the 'wipe data / factory reset' (HIGHLY RECOMMENDED)
- Select the 'advanced -> wipe Dalvik cache'
- Return to main menu of cwm by pressing the back button, select "install zip from sdcard -> choose zip from sdcard 'and select iTimmy.zip who had
already downloaded
- Installing the ROM will run, wait until the finish. Yaaaa ... please be patient
- Once there is a notification that the ROM installed, please reboot mmediately you x8
(The first boot takes less than ~ 3 minutes)
- At first boot, x8 will restart 3 times, but this not the big problem really. After that would normally and running smoothly
6. Enjoy iTimmy ...
Note:
- Recommendation: - use the sdcard least class 4, so that no lag when running the application
- For how to partition, for example if the 8GB sdcard: 6500MB FAT32 (as primary),
1024MB EXT3 (as primary, 256 MB Linux Swap (as primary)
*) Note: when the partition using the card reader, do via usb
after the partition is ready, just set it via A2SDGUI ...
For screenshot here:
