PRallday168
CM10.1 Tablet UI
This is CM10.1 with Tablet UI for the Kindle Fire HD 7", it is built on Hashcodes rom. Nova launcher is installed by default as Trebuchet does not cooperate with Tablet UI.
FEATURES:
Hashcodes CM10.1
Dual Pane View Style Settings
TabUI is Independent of DPI Changes
Nova Launcher beta 2.1 is default launcher *set desktop width margins to none for best results, change grid size to your preference!*
As I figure more out I will be adding to this
Instructions:
1. Wipe System/Data/Cache/Dalvik
- Data Wipe Needed! Do it! If coming from amazon, WIPE.
2. Flash ROM
3. Flash Latest GAPPS
4. Flash Play Store DPI fix *Mandatory*
5. Reboot
***If your tablet bootloops flash Hashcodes 1.2ghz kernel, this rom uses the 1.5ghz default overclock***
Download Link:
ROM: https://mega.co.nz/#!pVJynIoA!LIiPOg...eFu4z3XiEH9OXI
GAPPS: Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip
GPLAY DPI FIX: https://mega.co.nz/#!8VonnAyL!Z7rsHT...G902t3LGq49KVA
AuxLV for the TabletUI initiative
Hashcode For Bringing Cm10.1 To Our KFHD!
Bugs:
This rom is built on Hashcodes CM10.1 so any bugs you may have found in his rom are also likely in this. Everything seems to be fully functional other than what already wasn't and the TabUI works without a hitch. I will keep this updated as Hashcode updates his rom for those of you who want to use it.
Link to OP-- http://forum.xda-developers.com/showthread.php?t=2265465
HUGE THANKS TO Jester6 !!!!
