Root [ROM][6/20/12]Rejuvenation Rom V1.0 | Memory tweaks, Mods, Insane Speed and Stability
Rxpert83
Dr. Feelgood
Another ROM just came out. Posted by Husker91 on Xda.
Follow the thread here:
[ROM][6/20/12]Rejuvenation Rom V1.0 | Memory tweaks, Mods, Insane Speed and Stability - xda-developers
Version 1.0
Initial Release of Rejuvenated Stock!
Deodex and Zip-Align all system and framework apk's
All stock apps updated to current version
Advanced Power Mod
Long-Press volume to skip tracks mod
Camera tweaks including toggle-able shutter sound
360 and Landscape Rosie
Disabled HTC SmartSync to prevent data and wifi from sleeping
Quicksettings mod (thanks aamikam!)
Removed misc languages and unneeded setup files
Smooth Scrolling mod (like butter!)
Tweaked Auto-Brightness settings a little to my likings, bit brighter in brighter light, and lower in darkness...
No flashlight app included since there is a flashlight toggle in the quick settings
Added ES File Explorer, Hidden Settings app, and ICS Keyboard all of which are removable.
Tweaked Minfree settings for better multi-tasking and RAM Performance
(Revert zips will be included in the next update)
There's much more I'm forgetting, will update later
