Root [ROM]ANARCHY RELOADED by Mastermind, first custom rom for Micromax A73
Hey! Your rom seems to be working well in A73 except for a few very nasty BUGs..
1.The Playstore is not fully functional.. CANT DOWNLOAD anything! I had to install a previous version (v.3.8.16)
2. The phone seems to recognise only "EDGE" network! that is 2g.. My 3g (HSPA) network was not available! Hence browsing was terribly SLOW! and video call outta question!
3. The Dual sim functions were not Well Displayed! As in the stock rom, in the dialler, there is a clear option to use either sim1 or 2. but not present in your rom!
4. The Startup and switch off seems to take frustratingly longer..
5.Please provide a good simple CAMERA app!!
I am impressed by your work! But PLEASE do correct these in your next update!
Your fan, Hari! :D
pls solve the 2nd problem first because i have solved 1st,3rd,4th and 5th also so pl do for 2nd no problem
dear mastermind I wanna thanking for making such a nice rom but I am facing a problem that I am unable to use auto rotate function is not working plz tell me what to do I have also installed ur update but nothing works yet.
Hey guys.. im tryin to port coolpad 5860 rom to my mmx a87..
Both have similar specs.. which boot.img shud I use?.. the one from my stock rom,?
Hi Friend Need your all help..
I have upgrade to the ANARCHY ROM by mastermind on my micromax a73. The upgrade was sucessful but the signal bar was dead, but my sim was working fine when i place it to other mobile.
In the above thread i could find to replace the firmware folder with BT. what is BT? Please help me on this to solve the signal problem
BT is the name of ROM its Blue Terror but you can try just flashing this zip what i had provided in the link so download it and flash it in recovery hope it helps.
A73 Latest Stock Baseband
Super custom ROM!! @ mastermind1024...installed its updates too, but the 3rd party camera app you provided in the ROM is bit grainy :-(...I want the stock camera app back. Hope you have an update for this issue please.
Thanks a lot Shahabaz,
Could you please clarify if i can install a different rom for micromax a73( for examp. rom of mmx a75 or different model)
If so what files need to be modified incase to work with mmx a73?
Can I use this rom on my Micromax Ninja A57 because there are none for my device and this is a brilliant piece of work!!!:(:(
Thank You
another question-- in the first post it is written under features section "android 2.3.5" but screen shots show android version to be 4.0.1
Which version is it actually???:confused:
U can use ROM of any other phone whose specifications matches with ur phone u have to flash d rom n then flash d boot n logo zip n also d baseband zip n haan u have to make some changes in d build prop like phone model number launguage n d tweaks n haan if camera doesnt work den u need to make necessary changes accordingly.
The charging of my battery is falls fastly after reaching the level of 25%.
(यदि मै नेट चलाते रहु या गाना सुनते रहु तो 25% तक बैटरी अच्छा चलता है, पर 25% के बाद 5 min में ही1% में पहुच जाता है,और stand by में भी 25% के बाद 1/2 hour में ही 1% हो जाता है,)
And when i charging the on switch off mode it shows that 50% of charging completed but when i turn phone on it shows 20-30%, again switch off the battery shows more than 50% ,,,,,
Please help me. And solve the problem.
I am using ur rom in my micromax a75 and its working very smooth and i thank u for ur greate work...
see actually what i want from u is tell me that how could add my newly installed apps to rom so that when in future when i install this rom in my phone so i should get all my apps...
if u didnt understood then i tell u with an example
see i installed apps like mxplayer,dictionary,temple run etc and i want these apps to be added to the rom so that when i reinstall your rom i have not to the tedious work installing all the apps once again
please help me
Kindly please share me the link of BT rom to download and solve the network problem with replacing /etc/firmware file from BT rom to Anarchy i have googled a lot but dint find BT rom any were.....
Thanks
Dear sir thanx for the fantastic rom I have jst flashed this rom.. but for some reason my mobiles left side touch response is not working.. Plz help how to fix it or this is somthing hardware problem
sir im a new her and i am interested this rom.
im using a45 mtk6573 2.3.6.
can i port this rom?
the different of two is the 3G'-
THE WAIT IS OVER
HERE IS THE FIRST EVER CUSTOM ROM FOR MICROMAX A73
PRESENTED TO YOU BY
~# MASTERMIND #~
ANARCHY RELOADED
Features:
- ANDROID 2.3.5
- Pre-rooted
- Odexed (For faster boot & save space on /data)
- Busybox installed
- Nice boot animation sound
- Added ICS boot & shutdown animation
- Bravia Engine
- Beats Audio + xLoud mod
(removed in update 1.1)
- Cyan Over-scroll
- Video calling supported
- Updated Android Play Store to the latest version available (3.8.17)
- Added File Manager by Rhythm Software (Free app, Root explorer support)
- Replaced default camera app with lgCamera app (free app)
- No more grainy camera
- Battery percentage (in steps of 1%) display
- Nicer battery low noification popup
- Battery full charged notification
- Latest Holo Launcher as default launcher
- Added AdFree app & hosts to system hosts file (blocks ads in several applications or games)
- MTK CPU Control app (free app)
- Updated APN list for Indian service providers
- Changed lock screen interface to ICS style (somewhat)
- build.prop tweaks to improve pictures and video quality, increase touch responsiveness and improve battery life
- Cosmetic changes to the stock theme
- Most notification icons in cyan color
- Properly configured Network icons to ICS style including roaming icons (Self modded)
- Use sim background color of your choice, Network icons will not be affected (Screenshots 6,7)
- Transperent notification center
- Added ext2 filesystem support (ext2 fs now works with Link2SD)
- Added init.d support (self modded boot.img)
- Disabled Dalvik verify-bytecode to speedup ROM
- Wifi bug solved
- Volume Rocker Wake Mod (Use Vol Rocker to wake the device)
- Mod to show downloading file name in cyan color in notification center
- Mod to show playing song name in cyan color in notification center
- Mod to show sim label even with transperent sim background (that's orange in 2nd row)
- Ability to write IMEI numbers in Engineering Mode
- Google Maps 6.1.1 (mmx stock version is 5.11.0)(Note: Highest possible version i found showing proper gps location, latest maps not showing. This is the case with A75, not sure about A73)
INSTRUCTIONS TO INSTALL ROM:
1) You must have CWM Recovery to install the rom.
2) Copy the Anarchy_Reloaded_by_Mastermind_A73.zip to root of your sdcard
3) Switch off the device & boot into Recovery mode by holding down Vol Up key & Power On.
4) Back up your current ROM. (This is must if u run into some problem to restore)
5) Now, Wipe data/Factory reset
6) Install zip from sdcard
7) Choose zip from sdcard
8) Select copied ANARCHY rom zip file
9) Confirm the action
10) ROM installed
11) Reboot system
DOWNLOADS:
1) ROM: ANARCHY_RELOADED_by_Mastermind_A73.zip
CREDITS:
- A73 users shahabazas & falesh for testing A75 rom on A73
- I have made some changes on this rom now n its not tested yet, so putting a BETA tag.1st few testers will qualify for credits list.
- gta, 1st tester
- drsparsh, 2nd tester n beta tester
KNOWN BUGS:
- Network bug solved
- front camera 90 degree rotated left
- Do report if u find one
REMOTE POSSIBILITY:
- If after flashing rom shows bootanimation but does not get home screen, then just reboot to recovery n reflash the rom zip, this time it will start without a hitch.
ADDITIONAL NOTES:
- 1st boot may take some time, keep this in mind
- Apps in screenshots are not included(e.g.Facebook,Whatsapp etc.), this a basic rom package only to keep the rom size low.
- Requests are invited for changes or app packages
- Int2Ext+ is working fine (U can find it here, just flash the zip)
DISCLAIMER:
I am not responsible for bricked devices, dead SD cards, thermonuclear war, or you getting fired because the alarm app failed. Please do some research if you have any concerns before flashing! YOU are choosing to make these modifications, and if you point the finger at me for messing up your device, I will laugh at you.
UPDATES:
- For updates, see 2nd post
SCREENSHOTS:
They are from my A75, wait for someone with A73 to post his/her screenshots.
DON'T FORGET TO HIT THANKS IF U LIKE MY WORK
# AND GUYS/GALS(if there is any:D),PLEASE DON'T QUOTE THE WHOLE POST #
I have used this rom for quite a while and it is magnificent. But I really need to knw does this support swap
guys swap is not working .....plz help me out....
I want to increase ram...
I used ram expander app...n it is prompting to me that your kernal is not supported by our application ...
if any suggestions ....plz provide me...on my email id: adeshp23@gmail.com
my phone is micromax a73
I'm also a newbie and trying to update my ROM with this. I already rooted and taken backup using CWM Recovery. The backup folder contains images such as
1) boot.img
2) cache.yaffs2.img
3) data.yaffs2.img
4) recovery.img
5) system.yaffs2.img
6) nandroid.md5
7) .android_secure.vfat.tar
or same as the structure given by Mastermind?
