Root [ROM] barebones 2.0 11-28-12 *links up
1-3 messaging.. 4-7 launcher.. 8-11 browser
  • Total voters
    16
bones420la
^^^choose one from each category or post suggestions. where i end up going with this rom all depends on the feedback i get
ive been away from the forums a little too long. but im back and ive comletely rebuilt my barebones rom. right now its only slightly tweaked.. more to come in the future. im gonna use this to base a few more roms off of. more than likely in this same thread.
thanks goes out to everyone in the spectrum community... mainly the following
PlayfulGod > Death2All110 > MegahostGamer > wissowisso > neph > jcase > tdm
from the play store > appsdev > jmbc > ES Mobile > Modoohut > Mobint Software
Nicholas Workshop > Mapquest > Omkar Deshmukh > ChainsDD > USWeb Inc
Features
primo launcher 1.0.2
exdialer
holo locker
alarm clock ultra
google calendar
exdialer
es file explorer
instamusic
mapquest
messaging7
uc browser HD
google voice
tweaks
on screen navigation buttons enabled
stock lock completely disabled
bugs/issues
none as far as i know.... i didnt change the updater script much from playfulgods. that will be fixed in the next update. if anyone runs into any other issues or bugs let me know. and ill see what i can do about getting it fixed.
still working on the op.. im gonna keep updating it until its finished.. just keep checking back
link barebones2_112812_2205.zip ::. | by bones420la for Generic Device
PlayfulGods stock deodexed zv7 base
deleted
  • /system/3rdparty
  • /system/helpcenter
  • /system/vendor
  • /system/app/
  • aetherpal.apk
  • analogclockwidget.apk
  • basyncclient.apk
  • basyncservice.apk
  • blockbuster.apk
  • bluetoothcontrollerwidget.apk
  • books.apk
  • buaplus.apk
  • calendarwidget.apk
  • carhome.apk
  • chargingwallpaperpicker.apk
  • deskhome.apk
  • digitalclockwidget.apk
  • emailwidget.apk
  • favoritecontactswidget.apk
  • finance.apk
  • friendspluswidget.apk
  • gallerylg2.apk
  • gmail.apk
  • gms_maps.apk
  • helpcenter.apk
  • hotspotprovision.apk (no need since hotspot dont work
  • htmlviewer.apk
  • intouchwidget.apk
  • keychain.apk
  • kindle.apk
  • lgalarmclock.apk
  • lgbrowser.apk
  • lgcalculator.apk
  • lgcalendar.apk
  • lgcalendarprovider.apk
  • lgcontacts3.apk
  • lgemail_vzw.apk
  • lghome3.apk
  • lgolf2.apk
  • lgusmms.apk
  • lgworldclockwidget.apk
  • lockscreen.apk
  • lockscreensettings.apk
  • marketupdater.apk
  • memowidget.apk
  • messagewidget.apk
  • mlt.apk
  • mobilehotspot.apk
  • mobileupdateclient.apk
  • music2.apk
  • musicfx.apk
  • musicplayer.apk
  • musicwidget.apk
  • myverizon.apk
  • nativelivewallpaperspicker.apk
  • netflix.apk
  • nativemagicsmokewallpapers.apk
  • news.apk
  • nfl.apk
  • nfshp.apk
  • nightscapecw.apk
  • photoalbumwidget.apk
  • photoframewidget.apk
  • plusone.apk
  • pouchlockscreen.apk
  • powercontrolwidget.apk
  • raphsody.apk
  • richnote_vzw.apk
  • risingtidecw_rs.apk
  • scorecenter.apk
  • slacker.apk
  • smartmoviehd.apk
  • smartshare.apk
  • streamingplayer.apk
  • street.apk
  • swype.apk
  • talkback.apk
  • todaypluswidget.apk
  • tunewiki.apk
  • vcastapps.apk
  • vcastappsinstaller.apk
  • vcasttones.apk
  • vcastvideo.apk
  • videocallingportal.apk
  • videoplayer.apk
  • videos.apk
  • videosurf.apk
  • voicerecorder.apk
  • vvm.apk
  • vznavigator.apk
  • weatherwidget.apk
  • wiper.apk
  • youtube.apk
swapped supersu for superuser from the market
edit system/etc/settings.xml
add
  • alarm clock ultra
  • google calendar
  • es file explorer
  • exdialer
  • hololocker
  • instamusic
  • mapquest
  • messaging7
  • ucbrowserHD
  • voice
FAQ
Hey, appreciate your work on this. I haven't installed the ROM yet but I was wondering, is it possible to disable the onscreen navigation buttons on this?
yeah. under the settings in es file explorer make sure everything under root settings is checked and then edit the file /system/build.prop delete the lines
[HIGH]# on screen buttons
qemu.hw.mainkeys=0[/HIGH]
Installed this morning and I have to say it looks promising - very smooth and clean. Unfortunately I couldn't get my exchange account setup (which I need) so I had to switch back. I'd love to try it tho if we can get exchange working.
I really liked your first rom. Does this one have the inverted AOSP Messages app like the other one did?
not now.. i may switch to that one.. or add it in.. right now ive got it using messaging7 looks just like wp7... everything works as it should... plus im a fan of their messaging app
if anyone can throw up some ideas of what the best exchange mail app to throw in i will... personally i dont use it. and the lg email app just annoys me. so i normally remove it.
I tried loading emoze on this rom this morning before switching back and it wouldn't authenticate. Possibly a cert issue?
In the slimdroid rom they have the black statusbar instead of the stock. I really like this but personally don't like the other stuff about the rom. I think it would be pretty awesome if we could get that in the next rom.
If you would like the status bar from this rom all you will need to do is.....cd to the directory with adb in terminal/command prompt. and do
adb pull /system/app/SystemUI.apk
this should pull that file and put it on your computer. then all you need to do once your on the rom you want is cd back to the directory with adb. and do
adb push SystemUi.apk /system/app
and reboot and you should now have the black status bar with whatever rom you like :-)
Anyone else having a problem w/ google calendar not syncing? It keeps saying it's having problems & I should wait but never works. I don't have a problem w/ that for any other ROM.
I had this same issue. The best thing to do I found was to uninstall that one from the system and redownload it from the play store. You'd have to use a system app uninstaller though like titanium backup
I appreciate the reply. But I'll probably be sticking w/ a rooted stock ROM until some kinks get worked out (namely, usb connection issue). But, if there was a custom ROM I'd go w/, it'd be this one.
everytime I try this it says that 'adb' is not recognized as an internal command...?
What is the CD command? I'm really new to the cmd prompt side of developing. And what would be the path to the adv file add well
Open the command prompt, then type 'cd' without the quotes. It means change directory. The path to the adb file is somewhat unique for each person. For example, if you put the sdk directory on your desktop, the path would be something like this: c:\Users\'your_username'\Desktop\sdk\platform-tools
usb connection is no longer a problem for me... ive been using airdroid.. il probably include it and the working wifi tether in my next update... but on this rom i get a good 9 1/2 hours of life on 4g with wifi tether on the whole time running pandora on my nexus 7...
Just out of curiosity, what would be the result of me doing this while on the cm9 rom (pulling the systemui.apk) and then pushing it in a different rom??
from cm9 to a kanged version of cm9 it probably wouldnt hurt anything... but i doubt that the systemui.apk from cm9 would work with a stock based rom
