This is a beta release of AOKP for the Optimus Elite so please don't expect this to be 100% stable. You may get random reboots and lockups or you may not. Before flashing this rom I recommend you make a NAND backup just in case.
About: (taken from the aokp website.)
What is AOKP?
AOKP stands for Android Open Kang Project. It is a custom ROM distribution for several high-end Android devices. The name is a play on the word kang and AOSP (Android Open Source Project). The name was sort of a joke, but it just stuck, just like our infatuation with unicorns.
We fork the source code of Android that Google puts out in the open with every major version release, and we then add the magical unicorn bytes (read: we add some of the coolest features that are both useful and make your ROM awesome).
With AOKP, you can generally do a lot more with your device than what you could do with the original firmware that came installed on it.
What works:
What's partially working:
Issues:
Installation instructions:
To install this rom you must first have a custom recovery installed onto your phone.
You can learn how to do this here " http://androidforums.com/elite-all-things-root/620742-faq-guide-clockworkmod-optimus-elite.html"
F.A.Q
Q. What settings do I use to get tethering to work?
A. Device-Profile: Generic ICS/JB (wlan0)
Change Setup-Method: WEXT (ad-hoc)
MSS clamping checked
Routing fix checked
Want to report a issue you are having with the rom? Then use getlogs.
[APP] GetLogs - Get dmesg, logcat, radio, etc with one click! - xda-developers
Will update this post later
Change Log
Credits and thanks:
AOKP (link to website)
Cyanogenmod (link to website)
LG
Dorregaray (donation link)
G60madman
Downthemachine
Giantpune
Starkraving
Dev-Host
and everyone else I missed.
PATCHES:
Issue tracker:
Issue tracker
Gapps:
Dev-Host - gapps-jb-20121011-data.zip - The Ultimate Free File Hosting / File Sharing Service
Virgin Mobile:
Dev-Host - VMAOKPm3s-ota-eng.phenomx4(12-30-2013).zip - The Ultimate Free File Hosting / File Sharing Service
Sprint:
Dev-Host - LSAOKPm3s-ota-eng.phenomx4(12-30-2013).zip - The Ultimate Free File Hosting / File Sharing Service
Screenshots:
While donating is not required to use this rom it's always appreciated
Donations:
What is AOKP?
What works:
- Audio/speaker phone
- Headset/headphones
- Calls and texts
- Touchscreen
- Lights/brightness
- Offline charging
- External SD
- Bluetooth
- Wifi
- Proximity sensor
- Overclocking
- Tethering using an app called "Wifi Tether for Root Users" from the play store with the settings used in F.A.Q below.
- Mass storage
- Camera
- Data (stuck on 1x but get 3g speeds.)
- NFC ( NFC tags and google wallet are non functional.)
- You tell me.
Issues:
- you may have random reboots or lock ups or you may not.
- Google Wallet doesn't work and opening it causes nfc to not work until you do a reboot. Will fix this soon.
- There may be some graphic issues on apps such as Google Maps.
- 1. Download the appropriate rom for your phone and then Gapps. (Gapps is needed if you need to use google services such as Google Play.)
- 2. You need to copy the downloaded rom and Gapps to your internal memory or your external memory.
- 3. Boot into recovery.
- 4. If you are coming from a Gingerbread rom you need to do a full wipe. (cache, davlik cache, data, and system.) If you are coming from an other ICS rom e.g CM9 then you just need to wipe cache and davlik cache.
- 5. Select install zip from where ever you put the files onto. So if you put it on the external sd card you would pick "Install from SD Card".
- 6. Install in the following order. "Rom and then Gapps"
- 7. Reboot.
F.A.Q
Routing fix checked
Change Log
HTML:
12-31-2013
Add ARMv7 - and especially Cortex-A9 - optimized string
Ignore some errors checks, they always occurs because broken GL drivers
Fix log spam: Failed to open libwvm.so
Triggering EarlySuspend based on BackLight brightness
Allow purging of asset bitmaps
Optimize gradient textures
Fix memory corruption in LayerRenderer::copyLayer
Plug memory leak that happens when reusing display
Fix texture corruption
Fix race condition in pthread_create()
Enable Crt screen off animation
Freed some ram
Add support for Cell broadcasting/CMAS (untested)
Fix bluetooth audio routing (untested)
Kernel undervolting support
Wifi mac address fix
Other thing I forgot about
10-21-2013
Fixed weather
Added option to swap internal and external memory cards.
10-20-2013
Initial release
Credits and thanks:
LG
G60madman
Downthemachine
Giantpune
Starkraving
Dev-Host
PATCHES:
HTML:
Camera fix
http://d-h.st/Uq2
Issue tracker:
Issue tracker
Gapps:
Virgin Mobile:
Sprint:
Screenshots:
Donations:
