This is a beta release of PAC-ROM for the Optimus Elite so please don't expect this to be 100% stable. You may get random reboots and lockups or you may not. Before flashing this rom I recommend you make a NAND backup just in case.
About: (taken from the PAC-ROM website.)
PAC-MAN ROM OFFERS A UNIQUE CUSTOM ROM EXPERIENCE WITH ELEMENTS OF
Cyanogenmod
A fully integrated part of PAC-man,
this aspect brings all the functionality of CM
AOKP
Bringing in the greatness of the All Powerful Unicorn.
PAC-man grabs rom control, ribbons, and many other aspects of AOKP
ParanoidAndroid
one of the most original aspects brought into this roms is
hybrid mode which gives you full control of your rom experience
What works:
What's partially working:
Installation instructions:
To install this rom you must first have a custom recovery installed onto your phone.
You can learn how to do this here " http://androidforums.com/elite-all-things-root/620742-faq-guide-clockworkmod-optimus-elite.html"
F.A.Q
Q. What settings do I use to get tethering to work?
A. Device-Profile: Generic ICS/JB (wlan0)
Change Setup-Method: WEXT (ad-hoc)
MSS clamping checked
Routing fix checked
Want to report a issue you are having with the rom? Then use getlogs.
[APP] GetLogs - Get dmesg, logcat, radio, etc with one click! - xda-developers
Will update this post later
Change Log
Credits and thanks:
PAC-ROM (link to website)
ParanoidAndroid (link to website)
AOKP (link to website)
Cyanogenmod (link to website)
LG
Dorregaray (donation link)
G60madman
Downthemachine
Giantpune
Starkraving
NetSpeedZ
Dev-Host
and everyone else I missed.
PATCHES:
Gapps:
Dev-Host - gapps-minimal-jb-20130115-signed.zip - The Ultimate Free File Hosting / File Sharing Service
Google Maps 6.14.4: (This version is the latest version that we can use without graphical glitches seen in the new ones.)
Dev-Host - Maps_6.14.4.apk - The Ultimate Free File Hosting / File Sharing Service
Virgin Mobile:
Dev-Host - vm696pac_m3s_4.2-milestone.1.release_20140502-160438.zip - The Ultimate Free File Hosting / File Sharing Service
Sprint:
Dev-Host - ls696pac_m3s_4.2-milestone.1.release_20140502-155321.zip - The Ultimate Free File Hosting / File Sharing Service
Screenshots:
Coming soon
While donating is not required to use this rom it's always appreciated
Donations:
Cyanogenmod
AOKP
ParanoidAndroid
What works:
- Audio/speaker phone
- Headset/headphones
- Calls and texts
- Touchscreen
- Lights/brightness
- Offline charging
- External SD
- Wifi
- Proximity sensor
- Overclocking
- Tethering using an app called "Wifi Tether for Root Users" from the play store with the settings used in F.A.Q below.
- Mass storage
- Camera
- Bluetooth
- Data (stuck on 1x but get 3g speeds.)
- NFC ( NFC tags and google wallet are non functional.)
- You tell me
- you may have random reboots or lock ups or you may not.
- Google Wallet doesn't work and opening it causes nfc to not work until you do a reboot. Will fix this soon.
- There may be some graphic issues on apps such as Google Maps.
- During booting up the screen will be blank but will turn on when finished.
- 1. Download the appropriate rom for your phone and then Gapps. (Gapps is needed if you need to use google services such as Google Play.)
- 2. You need to copy the downloaded rom and Gapps to your internal memory or your external memory.
- 3. Boot into recovery.
- 4. If you are coming from a Gingerbread rom you need to do a full wipe. (cache, davlik cache, data, and system.) If you are coming from an other ICS rom e.g CM9 then you just need to wipe cache and davlik cache.
- 5. Select install zip from where ever you put the files onto. So if you put it on the external sd card you would pick "Install from SD Card".
- 6. Install in the following order. "Rom and then Gapps"
- 7. Reboot.
F.A.Q
Routing fix checked
Change Log
HTML:
5-2-2014
Freed more ram. available ram is 394MB
Fixed bluetooth music playback (AD2P)
4-10-2014
Initial release
Credits and thanks:
LG
G60madman
Downthemachine
Giantpune
Starkraving
NetSpeedZ
Dev-Host
PATCHES:
HTML:
None
Gapps:
Virgin Mobile:
Sprint:
Screenshots:
Coming soon
Donations:
