Nope... Just upgrade device... Plus No offense to phenom cm11 is bad on the elite well because its KitKat and this phone was not made for it... I personaly think the only upgraded ROM that works great for the elite is phenoms aokp 4.2.2... It could but with a slight chance... Be possible to make a port of android L to the elite but the lag the slowness the battery drain... It would be no where near usable IMO...
The problem for me is battery a single reboot takes alot of my battery and it eats battery(without much apps) But I have to give it to Phenom he did make a pretty sweet port of kitkat! But for now even if there is a L preview port it wouldn't surprise me . Can you tell me what tweaks you've made for cm11?
Same... except the governor was different. Well I have no Idea what much I did to tweak harmonia but I get lots of battery life and K actually have alot of free ram(thus I changed from Aokp to harmonia)
Anyways hows the battery for you?
