Pure Vanilla 2.1 AOSP - well as much as reasonable
zach.xtr and I are pleased to offer Vanilla2.0! (BIG credits to zach.xtr for tweaking and help with getting all bugs worked out. zach.xtr truly made this blazing quick... and freed up TONS of internal phone storage!)
checkout the
change log for a full feature list and details.
Remember to donate to the developers that make this possible!
Credits:
bertoch for hosting and Linux help
dsixda for his time saving kitchen
Conap and
Decadenc3 for their BFS kernel with OC and for MMS fix -
[GPL]2.6.29.6 BFS Kernel Update 9/5/10 - xda-developers
Conap for his support and general help
punk.kaos for his Trackball notification/softkey fixes
Gnarlyc for his Android Builder for quick access to 2.1 AOSP source
Framework43 for his pioneering work with AOSP 2.1 builds and a few "Senseless" parts
darchstar for a few libs
nfinitefx45 from the Hero CDMA forum on his work for cache2cache
xda member beta testers (you ROCK)
other xda members for tips and tricks
SERIOUSLY... DONATE TO ONE OF THE DEVS ABOVE. IF IT WASN'T FOR THEM, YOUR ERIS WOULD BE THE PHONE THAT "COULDN'T"
Base Vanilla2.0 Features:
- All the goodness of Android AOSP 2.1 with root access superuser permissions
- Built from AOSP 2.1 source including all your favorite AOSP 2.1 apps!
- Custom sysint process to optimize ROM system settings
- Smart design for a tailored user experience (only turn on the features what you want!)
- Overclock support - default setting overclock to 710400
- Apps2sd and Cache2cache support (see instructions below)
- designed to be a stable everyday ROM
- Check out the change log below to see details
Download Vanilla2.0.3: http://zach.xtr.i6ix.com/Vanilla2.0.3.zip
MD5 checksum: 8a15ca3c277ceb2b6b0e4cfeff808a96
Vanilla2.0 Options:
GScript
For Vanilla2.0 we have compiled and incorporated the opensource GScript app (see
gscript-android - Project Hosting on Google Code) to load and one-click run user settings.
To setup your GScripts complete the following steps:
1. After opening GScript press the menu button and select "Add script"
2. A new window will open.
3. Press the Load file button
4. Select a script from the list (each is obviously named as to its function)
5. Ensure Needs SU? is checked
6. Now select "Save" and you have added your script
7. To run just select it from the list in the main GScript screen
8. You must reboot the phone for the change to take effect.
Wired Tether
For wired tether to work you must make sure that your computer has the appropriate RNDIS drivers. Learn how to do this at the android-wired-tether
Wiki.
Per
roirraW "edor" ehT:
The wiki incorrectly states, or implies, that Windows 7 includes the RNDIS support. Or at least, they imply that Windows 7 includes the RNDIS driver necessary. I can confirm that neither Windows 7 x86 or x64 works with tethering out of the box. The instructions for XP users are correct and also work for Windows 7. Just download HTCSync for your device (Eris) and install it, and it'll install the correct driver.
Performance Improvements:
I HIGHLY recommend setting your Animations (Spareparts) to either OFF or FAST for a much smoother, faster experience.
Free Internal Memory and Dalvik-cache heapsize - We have update default user settings to allow a larger dalvik heapsize of 24mb (think more space for apps to play) AND optimized how memory is freed up using Androids internal task killer.
Default min memory free:
