[ROM] CleanROM 1.2 Stock with Overclock and Wifi Tether
kenn
A dev over on central has put together a ROM based on stock that is pretty straightforward. It is the stock Optimus S ROM with Sprint Bloatware removed. It is using Picasticks overclock Kernel and is running at 748mHz. He has included ad blocking, superuser, and wifi hotspot in the built.
From what I've seen of it so far, it is fast, stable, and straightforward. If you are looking for a simple ROM to get rid of the bloat and speed things up a bit, this may be your Huckleberry.
http://forum.ppcgeeks.com/lg-optimu...verclocked-ad-blocked-wifi-tether-themes.html
His site: http://scottcrosler.info
I'm running it on one Optimus S and will probably put it on my second.
I'm in love with the Nameless ROM...if you have used it, how does this one compare to that one...if that made any sense?
