andriodadmirer
***************CM10.1 4.2.2 PORT******************
HEY THIS IS ANDROID ADMIRER HERE WITH A PORT FROM THE HTC MY TOUCH 4G
WHAT WORKS?
EVERYTHING AS FAR AS I KNOW
___________________________________________________
Install instructions:
1.boot into CWM
2.wipe data and cache
3.go to mounts and storage and
format cache, data and system
4.goto install from sd
5.select the rom and select yes
6.once it stopps select reboot now
I ALSO HAVE HERE THE 4.3GAPPS THAT WERE PULLED FROM THE GALAXY NEXUS
I TESTED THIS ALOT AND THESE ARE ALL COMPATIBLE WITH 4.2.2
SIDENOTES.....
TO ACTIVATE REBOOT RECOVERY IN THE POWER MENU (OPTIONAL)
if you want to unlock the reboot recovery option in the power menu
a.goto system settings
b.scroll all the way down to "about phone" and select
c.scroll all the way to the bottom to the build number
and tap it repeatedly
it will do a 123 countdown
d.go to developer options and check the advanced reboot box
then you will have it
playstore.....
>>>>>>>BEFORE YOU INSTALL THE 4.3 GAPPS <<<<<<<<<
SIGN IN WITH YOUR GOOGLE ACCOUNT AND LET EVERYTHING SYNC UP!!!!
AND LET THE PLAY STORE UPDATE AS WELL THE MOST RECEN
THEN YOU CAN INSTALL IT (TRUST ME,I LEARNED THIS HARD WAY)
HERE'S THE ROM LINK
https://db.tt/FGUlX05C
Heres the gapps
https://db.tt/G56JkNN0
WHAT WORKS?
1.boot into CWM
SIDENOTES.....
playstore.....
HERE'S THE ROM LINK
Heres the gapps
