Root [ROM][CM10.2][JB4.3.1][JLS36I] Beanstalk Build 4.3.1015 [10/26]
ROM is fantastic for the most part. I love all the customization options, and I only had one reboot which was during setup. Almost everything seems to work.
However, SMS does not work for me. I can receive them, but I cannot send them. Oddly enough, MMS seems to work just fine.
This is from a clean flash. I will test other things tomorrow.
Thank you for taking the time to build/port this and share.
Edit:
This ROM seems to have the Xposed framework. However, when I went into Xposed installer to activate some modules, I got this message
cannot write /data/xposed/modules.whitelist
It then displays
The xposed framework is not installed
So clearly it is not able to activate modules. And although I can check the boxes, after a reboot the boxes are unchecked and the modules do not function.
Xposed Installer itself seemed to think the framework was there and fully functional. But when I tried to remove it, both ways, I got another error. I unfortunately did not remember to write it down. I did find a fix though. I deleted the Xposed Installer app and downloaded the latest version from the developer. That version was able to remove and then reinstall the framework, and now all of the modules I've tried work like they are supposed to. So no big deal there, but I figured I would point it out.
Edit:
It then displays
Yeah, the dev for the xposed framework isn't *against* people bundling xposed into their roms... But he stron**y recommends that you dont, and direct people to get the latest version (and download whatever module pack you need to make the rom look like you want).
Tried this rom last night. It's very nice and has a lot of customizations, but it has a few glitches so can't be my daily driver: Some Gmail, SMS, Startel Secure Messaging (HIPPA requirment), Address book come up black and can't read the text. Try to play with different themes, turning Beanstalk black mode on and off, different launchers that were included in the ROM--still the problem exists frequently. Clearing cache and restarting apps sometimes help. Hot booting helps for a little while. Cold booting helps for a lilttle while. Yet, the problem comes back. Voice works fine. ROM is nice and smooth (as fast as CM10.2 10/26). 4G Data needs rebooting to obtain but works fine. GPS works fine. Free ram is only 320 MB instead of 420MB on CM10.2.
This rom works great, except for the battery life issue that I am experiencing. This is the first JB rom that I've used that doesn't have apps crash regularly, but the battery life has been horrible (~5-6hr full charge). I would love to keep this as a daily driver, but I must search for something else.
Hello,
Please forgive this n00b's ignorance. The last android phone I had was an LG ally that I rooted to just uninstall the bloatware. That was close to 4 years ago now. I have an LG spectrum that just bogs down sometimes to the point where I cannot even make a phone call.
Decided to root and update. I rooted using the 1 click option found here:
http://androidforums.com/spectrum-a...20-bootloader-pwnage-tool-lg-spectrum-4g.html
It was super easy, and now I want to update my rom.
On the first post of this thread I clicked on the download for gapps, and have that downloaded no issue, but for the rom and kernal links, what do I do?
I click on the links and see a list of folders. I am not sure which one to pick or how to find the rom. and do I have to unzip them to the sd card or copy over the zip.
If there are clear instructions on the forum I couldn't find please let me know.
Hello,
Download newest ROM zip and gapps to match. Copy to somewhere on your SD. No need to unzip. Reboot to recovery... Wipe data. Wipe cache. Wipe dalvik cache. Install ROM zip. Install gapps. Reboot. Profit
Helps if I click on the right links... I clicked on "kernel source" and not "DOWNLOADS" Gad I'm an idiot... that's why i was confused. Thanks for your help!
Ok, so I got it to the screen where it says beanstalk, has a picture of a beanstalk, and rain is falling, been on this screen for about 20 minutes. any idea how long it should sit here? I thought I read that the first boot takes a long time. how long is long?
You forgot to wipe data and dalvik in recovery?
I did, I got it to work by just trying it again. battery life seems to be shorter... but other than that works 10000x's better. it doesn't constantly crash like the stock OS.
