Root [ROM]CM10 - Boost Force[WIP]
junkie2100
Android Expert
DISCLAIMER: This is a CUSTOM ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, CyanogenMod 10 for the Boost Force!!! Well, let's be honest, unless you're living under a rock, you probably know what Android 4.1 (JellyBean) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod | Android Community Rom based on Jelly Bean
Developers: 1mouse3 and junkie2100
Description: CyanogenMod 10 for the Boost Force
Source: https://github.com/junkie2100/android_device_zte_aurora
Status: BETA
CyanogenMod 10 What is this? This is a build of the popular CyanogenMod 10 for the ZTE Force N9100. This is built from source.
People to Thank
  • koush - for his kickass recovery.
  • CyanogenMod - for the best ROM out.
  • Totlth - for the original source we started with an his suggestions
  • Dadcup - for the various fixes he has passed along to us from his work on the avid
  • DM47021 - for his various fixes and tweaks
  • PlayfulGod - for throwing in various suggestions and teaching me a good portion of what i know about cm development
  • numerous testers - thanks for testing & keeping the faith. ;)
  • IRC - for the ongoing help and shared knowledge.
    ** #upp (Skyn3t)
    ** #oudhitsquad (Freenode)
    ** #cyanogenmod-dev (Freenode)
    ** #koush (Freenode)
  • and anyone else i may have forgotten
Screenshots
N/A
How do I install this?
[1]Download the .zip & copy to the sdcard (make sure wifi is enabled if dl'd from phone).
[2]Zip can be installed from the external sd in CWM
[3]MAKE A BACKUP!!!
[4]DO A FACTORY RESET!!! - this will wipe data & cache!
[5]Go to install zip from sdcard
[6]Choose zip from sdcard
[7]Select cm10-force.zip
[8]Confirm
[9]Repeat Steps 5 -8 for gapps
[10]Reboot
Downloads
Known Bugs
Code:
This list will be updated as we find them and fix them.
WiFi:
 -does not even turn on
Settings:
 -the storage menu crashes settings
Sensors:
 -proximity sensor is non functional
Camera:
 -front camera is upside down
i really have not a clue. we can work on issues like that after the big things, namely wifi and proximity sensor. if someone else can verify that it is a cm bug and not a fluke i will add it to the list of known bugs though for future reference. id add it now but knowing that sometimes it could just be one phone out of a million it happens to i dont wanna try to fix something that isnt really broken lol
yep i would assume so except for possibly needing to change the apn for sprint instead of boost to get mms and 4g working properly
<?xml version="1.0" encoding="utf-8"?>
** Copyright 2012, Cyanogenmod
** Licensed under the Apache License, Version 2.0 (the "License");
** you may not use this file except in compliance with the License.
** You may obtain a copy of the License at
** http://www.apache.org/licenses/LICENSE-2.0
** Unless required by applicable law or agreed to in writing, software
** distributed under the License is distributed on an "AS IS" BASIS,
** WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
** See the License for the specific language governing permissions and
** limitations under the License.
<!-- use empty string to specify no proxy or port -->
<!-- This version must agree with that in apps/common/res/apns.xml -->
<apns version="7">
<apn carrier="MobiPCS" mcc="310" mnc="00" apn="MobiPCS" user="@mobipcs.com" password="mobipcs" mmsc="http://mms.mobipcs.com" authtype="3" type="*" />
<apn carrier="Cricket" mcc="310" mnc="16" apn="wap.mycricket.com" user="@mycricket.com" password="cricket" mmsc="http://mms.mycricket.com/servlets/mms" mmsproxy="" mmsport="" proxy="wap.mycricket.com" port="8080" authtype="2" type="*" />
<apn carrier="Cellular South" mcc="310" mnc="023" apn="internet" mmsc="http://pix.cellularsouth.com/servlets/mms" authtype="3" port="" mmsport="" type="mms" />
<apn carrier="MetroPCS" mcc="310" mnc="027" apn="wap.metropcs.net" user="MDN@mymetropcs.com" password="metropcs" server="http://mms.metropcs.net/servlets/mmsc" mmsc="http://mms.metropcs.net/mmsc" mmsport="3128" type="default,supl,mms" />
<apn carrier="Virgin Mobile US" mcc="311" mnc="490" apn="0" mmsproxy="205.239.233.136" mmsport="81" mmsc="http://mmsc.vmobl.com:8088/mms?" port="" type="mms" />
<apn carrier="Boost MMS" mcc="505" mnc="02" apn="mms" user="" password="" server="" proxy="61.88.190.10" port="8070" mmsc="http://mmsc.optus.com.au:8002/" mmsproxy="61.88.190.10" mmsport="8070" type="mms" authtype="3"/>
<apn carrier="Boost Mobile" mcc="505" mnc="02" apn="yesinternet" user="" password="" server="" proxy="" port="" mmsc="" mmsproxy="" mmsport="" type="default,supl" authtype="3"/>
<!-- MetroPCS: LTE Apn -->
<apn carrier="MetroPCS DEFAULT" mcc="311" mnc="660" apn="internet.metropcs" user="" password="" type="default,hipri,admin,mms" authtype="0" mmsc="http://mms.metropcs.net:3128/mmsc" protocol="IP" roaming_protocol="IP" bearer="14" inactivity_timer="7080" />
<apn carrier="MetroPCS IMS" mcc="311" mnc="660" apn="ims.metropcs" user="" password="" type="ims" authtype="0" mmsc="http://mms.metropcs.net:3128/mmsc" protocol="IP" roaming_protocol="IP" bearer="14" inactivity_timer="7080" />
<!-- end MetroPCS: LTE Apn -->
<!-- Sprint -->
<!-- Sprint CDMA MMS: Use LTE/eHRPD mms apns to avoid LTE/eHRPD service conflicts. -->
<!--<apn carrier="Sprint" mcc="310" mnc="120" apn="Sprint" user="Sprint" server="*" password="*" mmsc="http://mms.sprintpcs.com" authtype="3"/>-->
<!-- Modify Apn database for Sprint LTE support -->
<apn carrier="LTE - SPRINT test ISP" mcc="001" mnc="01" apn="n.ispsn" type="default,mms" mmsc="http://mms.sprintpcs.com" mmsproxy="68.28.31.7" mmsport="80" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - SPRINT test OTA" mcc="001" mnc="01" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - SPRINT test PAM" mcc="001" mnc="01" apn="pamsn" type="dun" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - SPRINT test ISP" mcc="001" mnc="010" apn="n.ispsn" type="default,mms" mmsc="http://mms.sprintpcs.com" mmsproxy="68.28.31.7" mmsport="80" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - SPRINT test OTA" mcc="001" mnc="010" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - SPRINT test PAM" mcc="001" mnc="010" apn="pamsn" type="dun" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<!-- END modify Apn database for Sprint LTE support -->
<!-- Modify Apn database for Sprint EHRPD support -->
<apn carrier="EHRPD - SPRINT test ISP" mcc="001" mnc="01" apn="n.ispsn" type="default,mms" mmsc="http://mms.sprintpcs.com" mmsproxy="68.28.31.7" mmsport="80" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - SPRINT test OTA" mcc="001" mnc="01" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - SPRINT test PAM" mcc="001" mnc="01" apn="pamsn" type="dun" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - SPRINT test ISP" mcc="001" mnc="010" apn="n.ispsn" type="default,mms" mmsc="http://mms.sprintpcs.com" mmsproxy="68.28.31.7" mmsport="80" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - SPRINT test OTA" mcc="001" mnc="010" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - SPRINT test PAM" mcc="001" mnc="010" apn="pamsn" type="dun" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<!-- END modify Apn database for Sprint EHRPD support -->
<!-- Sprint LTE/eHRPD: These apns are added then programmatically removed in S3 LG8 build. -->
<!--<apn carrier="LTE - SPRINT OTA" mcc="310" mnc="120" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />-->
<!--<apn carrier="EHRPD - SPRINT OTA" mcc="310" mnc="120" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />-->
<!-- Sprint LTE/eHRPD: Programmatically added in S3 LG8 build. -->
<apn carrier="APN0 LTE ota" mcc="310" mnc="120" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="APN0 EHRPD ota" mcc="310" mnc="120" apn="otasn" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="APN2 LTE internet" mcc="310" mnc="120" apn="n.ispsn" type="default,mms" mmsc="http://mms.sprintpcs.com" mmsproxy="68.28.31.7" mmsport="80" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="APN2 EHRPD internet" mcc="310" mnc="120" apn="n.ispsn" type="default,mms" mmsc="http://mms.sprintpcs.com" mmsproxy="68.28.31.7" mmsport="80" protocol="IP" roaming_protocol="IP" bearer="13" />
<!-- END Sprint -->
<!-- Verizon Wireless -->
<!-- Modify Apn database for VZW CDMA MMS, internet, cbs, fota, and ims support -->
<apn carrier="Verizon" mcc="310" mnc="004" apn="internet" type="default,mms,dun" mmsc="http://mms.vtext.com/servlets/mms" protocol="IP" />
<apn carrier="Verizon Internet" mcc="310" mnc="004" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" />
<apn carrier="Verizon FOTA" mcc="310" mnc="004" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" />
<apn carrier="Verizon IMS" mcc="310" mnc="004" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" />
<apn carrier="Verizon CBS" mcc="310" mnc="004" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" />
<!-- Modify Apn database for VZW LTE support -->
<apn carrier="LTE - Verizon Internet" mcc="311" mnc="480" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - Verizon FOTA" mcc="311" mnc="480" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - Verizon IMS" mcc="311" mnc="480" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - Verizon CBS" mcc="311" mnc="480" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - Verizon SUPL" mcc="311" mnc="480" apn="VZW800" type="supl" protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Roaming Internet" mcc="204" mnc="04" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - VZW Roaming FOTA" mcc="204" mnc="04" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Roaming IMS" mcc="204" mnc="04" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Roaming CBS" mcc="204" mnc="04" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - Test Internet" mcc="001" mnc="01" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - Test FOTA" mcc="001" mnc="01" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - Test IMS" mcc="001" mnc="01" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - Test CBS" mcc="001" mnc="01" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test Internet" mcc="001" mnc="010" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - VZW Test FOTA" mcc="001" mnc="010" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test IMS" mcc="001" mnc="010" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test CBS" mcc="001" mnc="010" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test Internet" mcc="246" mnc="81" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - VZW Test FOTA" mcc="246" mnc="81" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test IMS" mcc="246" mnc="81" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test CBS" mcc="246" mnc="81" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test Internet" mcc="246" mnc="081" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - VZW Test FOTA" mcc="246" mnc="081" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test IMS" mcc="246" mnc="081" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<apn carrier="LTE - VZW Test CBS" mcc="246" mnc="081" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="14" />
<!-- END modify Apn database for VZW LTE support -->
<!-- Modify Apn database for VZW EHRPD support -->
<apn carrier="EHRPD - Verizon Internet" mcc="311" mnc="480" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - Verizon FOTA" mcc="311" mnc="480" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - Verizon IMS" mcc="311" mnc="480" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - Verizon CBS" mcc="311" mnc="480" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - Verizon SUPL" mcc="311" mnc="480" apn="VZW800" type="supl" protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Roaming Internet" mcc="204" mnc="04" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - VZW Roaming FOTA" mcc="204" mnc="04" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Roaming IMS" mcc="204" mnc="04" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Roaming CBS" mcc="204" mnc="04" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - Test Internet" mcc="001" mnc="01" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - Test FOTA" mcc="001" mnc="01" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13"/>
<apn carrier="EHRPD - Test IMS" mcc="001" mnc="01" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - Test CBS" mcc="001" mnc="01" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test Internet" mcc="001" mnc="010" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - VZW Test FOTA" mcc="001" mnc="010" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test IMS" mcc="001" mnc="010" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test CBS" mcc="001" mnc="010" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test Internet" mcc="246" mnc="81" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - VZW Test FOTA" mcc="246" mnc="81" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test IMS" mcc="246" mnc="81" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test CBS" mcc="246" mnc="81" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test Internet" mcc="246" mnc="081" apn="VZWINTERNET" type="default,dun" protocol="IP" roaming_protocol="IP" bearer="13" />
<apn carrier="EHRPD - VZW Test FOTA" mcc="246" mnc="081" apn="VZWADMIN" type="fota" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test IMS" mcc="246" mnc="081" apn="VZWIMS" type="ims" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<apn carrier="EHRPD - VZW Test CBS" mcc="246" mnc="081" apn="VZWAPP" type="cbs,mms" mmsc="http://mms.vtext.com/servlets/mms" protocol="IPV4V6" roaming_protocol="IPV4V6" bearer="13" />
<!-- END modify Apn database for VZW EHRPD support -->
<!-- END Verizon Wireless -->
<!-- US Cellular -->
<!-- Modify Apn database for USCC CDMA for MMS Support -->
<apn carrier="USCC" mcc="311" mnc="220" apn="internet" mmsc="http://mmsc1.uscc.net/mmsc/MMS" authtype="3" port="80" mmsport="80" type="mms" />
<!-- Modify Apn database for USCC LTE support -->
<apn carrier="LTE - USCC INTERNET" mcc="311" mnc="580" apn="usccinternet" type="default,dun,mms,fota" mmsc="http://mmsc1.uscc.net/mmsc/MMS" protocol="IP" roaming_protocol="IP" bearer="14" />
<apn carrier="LTE - USCC INTERNET 2" mcc="311" mnc="225" apn="usccinternet" type="default,dun,mms,fota" mmsc="http://mmsc1.uscc.net/mmsc/MMS" protocol="IP" roaming_protocol="IP" bearer="14" />
<!-- END modify Apn database for USCC LTE support -->
<!-- END US Cellular -->
<!-- Add proper Boost Mobile APN -->
<apns version="7">
<apn carrier="ota" numeric="311870" mcc="311" mnc="870" apn="otasn" user="null" server="null" password="null" proxy="null" port="null" mmsproxy="null" mmsport="null" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="fota" bearer="14" />
<apn carrier="ota" numeric="311870" mcc="311" mnc="870" apn="otasn" user="null" server="null" password="null" proxy="null" port="null" mmsproxy="null" mmsport="null" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="fota" bearer="13" />
<apn carrier="BOOST0 LTE ota" numeric="311870" mcc="311" mnc="870" apn="otasn" user="" server="" password="" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="fota" bearer="14" />
<apn carrier="BOOST0 EHRPD ota" numeric="311870" mcc="311" mnc="870" apn="otasn" user="" server="" password="" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="fota" bearer="13" />
<apn carrier="BOOST1 LTE pam" numeric="311870" mcc="311" mnc="870" apn="boost.pamsn" user="" server="" password="" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="dun" bearer="14" />
<apn carrier="BOOST1 EHRPD pam" numeric="311870" mcc="311" mnc="870" apn="boost.pamsn" user="" server="" password="" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="dun" bearer="13" />
<apn carrier="BOOST2 LTE internet" numeric="311870" mcc="311" mnc="870" apn="n.boost.ispsn" user="" server="" password="" proxy="" port="" mmsproxy="68.28.31.7" mmsport="80" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="default,mms" bearer="14" />
<apn carrier="BOOST2 EHRPD internet" numeric="311870" mcc="311" mnc="870" apn="n.boost.ispsn" user="" server="" password="" proxy="" port="" mmsproxy="68.28.31.7" mmsport="80" mmsprotocol="null" mmsc="http://mm.myboostmobile.com" type="default,mms" bearer="13" />
</apns>
<!-- END Boost Mobile -->
</apns>
^this is the apn that should work for sprint, also at the bottom i have added boost stuff but i am not using this one yet. i will probably switch to it at some point but for now it works the way i have it and there are more important things to worry about. i really need to submit my edit to cm as well, that would make things much easier for people in the future if they had a proper boost mobile setup for mms and lte
4g works and its blazing fast :) I had to download Google play services for the play store to actually let me download apps. So far its super stable.
4g work just that its set to 8 instead of 9, for now till he changes it dial *#*#4636#*#* an in phone info change it to LTE/CDMA auto (PLR)
I've noticed that the data drops ALOT!
cm and stock have different levels of compensation and a different number of signal bars even. so you will notice the occasional variance
im very glad to hear testing is going well though and that everybody likes it. also youll want to test the high definition media playback, if you can play a 720p video it should be fine, but i know on my phone i cant play high def stuff in the stock player, external apps work, straight from the gallery does not unless its standard definition. of course my camera and bluetooth dont work either but my wifi does so who knows. different phones different issues
So I ran into a problem. I tried playing some music and &#65279;the phone went haywire. It froze when I tried to play a song &#65279;the rebooted itself. I tried downloading a few other music players and they all froze or wouldn't even open. After that all &#65279;the apps I opened froze or fced upon opening them. So I reflashed and &#65279;the same thing happened again. Everything else that has to do with &#65279;the SD card worked fine but for some reason trying to play music killed &#65279;the rom.
Haven't had that issue. I've been playing music all morning
sometimes a badly formatted music file can do that. even the slightest bit of corruption can cause a crash. if you have a different sd card i suggest trying to put different music on there and playing that as a test
I don't know. I have 14 gigs of music on my card and none of &#65279;the files have given me any problems before. I guess i'll give it another go cuz I really like &#65279;the rom. But I can't live without my jams lol
I use power amp, maybe try that.
that does happen, i had like 200mb of music once and one file had some bad tag info so it would crash apollo every time. had to remove all my music and put new stuff on there
Its an issue with Bluetooth. I tried playing music through the phone speaker first and it worked. Paired my Bluetooth headphones and music crashed and won't play. Also Bluetooth isn't working for phone calls either. It says I'm connected but I'm getting nothing.
Ok, everytime i try to install this it tells me
assert failed: getprop("ro.product.device") == "aurora" || getprop("ro.build.product") == "aurora"
E:Error in /sd/cm10_force.zip
(Status 7)
Installation aborted
What am i doing wrong?
k, well ill see what i can figure out about that bluetooth thing, its hard to do when i dont have the device though and mouse doesnt even have a headset lol. and the assert thing to fix it the updater script will have to be modified, i dunno why it always puts that crap in there... i hate it, but i dont feel like screwing with the release tools
an alternative option is to change your buildprop in the current rom to reflect that, so it finds what its looking for
