Root [ROM] Codename Android
colchiro
Extreme Android User
Very popular Galaxy Nexus rom... highly customizable.
On Twitter: https://twitter.com/CodenameAndroid
Downloads, feature list and discussion in the forum on his website: Nexus 7 - Codename Android
If coming from a different rom (or stock), make sure you make a backup in recovery and wipe both caches and data. :D
Just installed.... very nice.
Now to make a nandroid and see if I can get my inverted apps to work. :D
This is my first rom for my N7... it was working nicely as stock, but I've been running CNA on my phone for about a month.
Currently trying this ROM out. I used Pure AOSP before with a tablet interface without DPI change.
So far i like it, has a stock feel with more customization. Feels stable as all heck.
It was an easy flash. I llike the extra choices, as that was the primary reason i used a tabletUI.
Wow, I just donated for him to Get an N7 so he could test, hard to believe this is already out. I'm not sure I'm ready to flash a ROM to my N7 yet, I'll see how stable CNA is on my GNex.
Anyone else gave this a go lately? Running great on my Galaxy Nexus, but haven't tried it on my N7.
Still letting it run on my phone. Couple things I'm noticing on that that are making me wait to load it on the N7.
Lightflow doesn't work (I know, no need for it on N7)
Volume seems to turn down on its own
stuff like that.
stuff like that.
Haven't noticed any of that. I haven't used Lightflow in a long time though. I'm really interested in flashing CNA because it allows for the different screen brightness settings and I think the N7 is too bright in low light situations. Should see some battery improvements. Should also see some battery improvements in the kernel.
I just want to make sure its clear I am in no way upset with the CNA rom. I love the mix of options and stock feel. I'm just not ready for it on my N7 yet.
My last post came across as nitpicky when I reread it.
stuff like that.
This Rom,s running great on the N7. I also had an issue with lightflow not working on the GNex so I tried a few things with no luck and ended up reinstalling it and its working good. (so far lol)
I can see they definitely need server help. The site isn't loading for me. :(
Just flashed 3.3 on my Gnex, maybe I'll give ROMing my N7 another shot.
So I flashed it on my Nexus 7. Started downloading apps from the Play Store and the whole tablet locked up. Power button wouldn't work no matter how long I held it. Had to pop the back off and do a battery pull. After that, it worked fine.
I do have one bug that really affects how I set up my ROMs and it affects my Galaxy Nexus as well. The custom screen brightness levels in settings does not work. Either crashes settings or sets the brightness to max and leaves it there.
Did you wipe data, cache and Dalvik cache before installing? Working great on my phone, but don't have my N7 here to flash latest.
Yes, I did a complete wipe. Did so on the Galaxy Nexus as well. May try fixing permissions and see if that helps
I like this rom but I started having graphic problems with one of my favourite time killers - robo defense. There would be a lag in screen movement, a delay in selecting options and a long delay in the home screen being displayed after exiting the game. This was using the motley kernel.
The issues went away when I went back to the bamf paradigm rom. When this is updated again I'll give it a more thorough look and see how it works with the stock kernel as well as motleys.
