Maybe, I have cwm and it works, I don't get the "error: can't mount "datadata" can't find "datadata"" or whatever and my backup restores perfectly including ext partitions.
QUICK TIP!
When flashing from an a2sd enabled rom to an a2sd enabled rom (e.g. mate35 to cm7 or vice verce) you can restore apps from your SD cards ext partition by opening terminal emulator and typing in "su" and allowing super user permission then typing "a2sd remove" phone will go nuts (matrix style in this piece!) And reboot (sometimes it doesn't reboot... give it 5min and reboot manually.).
All apps that were on the Sd .Ext will be on your phone. It transfers to ANY darktremmor a2sd enabled rom, most cyanogen mods for the ascend, optimus (M,C and possibly others but I haven't tested yet) and m835. I have cross transferred from and to these specific phones and the only issue I have had is with a solitaire app that got stuck displaying at m835 size on the ascend.
