swimman2867
What is the best way to delete a theme or add-on from the fission rom manager, or rom manager (general) for that matter?
I would install whatever swype you want over it or back up before you install upgrades so you can go back before you had it
Yea that is what I do.
I install Fission and back it up and then when I put themes on I back them up and then if I want to put a new theme on I restore back to stock Fission and put the new theme on and then back it up.
I am trying to help my brother with his D2. We rooted it and put on squidly's newest rom. If I switch him over to Fission, what steps in recovery should I do to flash this. Also when restoring a backup, do you wipe cache, dalvik cache and do a factory data reset like I do on the Ally? Thanks for any help.
I always wipe cache and wipe data/factory reset when loading new ROMs. Its a new ROM so its best to start fresh because flashing over can cause problems. You mount system and as I recommended wiping both then install from SD card.
Is it necessary/good idea to wipe data and cache when applying a theme?
Technically it's never necessary to wipe data and cache unless installing a new ROM. I never wipe when installing themes or when restoring a backup.
just a quick question. I have my phone rooted, ave the bootstrap recovery 2, titanium bkp which I have run and backed up everything, etc etc. getting ready to flash to the fission rom using the fission rom manager. question is, after I do so, if I dont like it or for whatever reason want to go back to stock, I can just do a full restore from my titanium backup? easy peasy?
thanks
DON'T DO IT YET!! , haha
T. BU is for APPS only (and data)
ROM Manager/recovery console (reboot into "recovery") is the way to back up an IMAGE - aka, your system as it was.
Cruise some of the threads and stickies on backup. Just make sure to backup the image, and restore as a test before you wipe and load another ROM.
Just my .02
I've read Titanium doesn't work well with some ROMs so I don't use it anymore. When you sync your market with your gmail account again, your apps should restore but your data won't.
