akhilkapila
This is a Custom Rom for Ployer Momo9 based India tablet Funbook by Micromax.
The rom will be compatible with all Ployer Momo9 based tablets but is only tested on the Indian Variant Funbook by Micromax.
By downloading the above rom you agree that after effects of installing the rom will be your own liabiliy. I will not be held responsible for that.
Follow the ROM on XDA
[ROM] Fun Series v1 - Custom Rom for Micromax Funbook ICS 4.0.3 - xda-developers
Flashing Procedure:--Changelog v1 - Initial Release
1. Init.d Support
2. Pre-Rooted (SuperSU form Chainfire)
3. Zippalligned all the APks
4. Added Bash - Useful for Scripts
5. Hardware Acceleration Enabled
6. GPU UI rendering
7. Adrenaline Boost - Best Ram Script
8. Adrenaline CPU Control
9. Lot of Build.prop tweaks
10. Hacked hosts file - No advertisements
11. Replaced Stock launcher with Apex Launcher
12. Removed Gapps such as Gmail, Youtube and Maps. Can be downloaded from market
13. I dont remember every thing....
Changelog v2 - 30-May-2012
1. Changed Base Rom from Momo9 to Micromax Stock
2. Bareboned - Pure Gaming Rom. No useless Apps
3. Added ICS Bar Hide Mod
4. Added SD card to Internal SD Mod
5. Added Unlocked Market
6. Ext4 Journaling Disabled - Faster Filesystem Less Lag
7. Added Lag Free v3 Script - No build.prop Tweaks needed
8. Added Beats Audio - Better Audio
9. Added BusyBox
10. Added Allwinner Mod App
11. Added Google Music 4
12. Updated Apex launcher
13. Text to Speech Working Flawlessly(TTS Service)
14. New Boot animation - Blue Solar Flare
15. Added Setup Manager - For a little bit of more convenience.
16. Some things can be added later...if forgotten
Changelog v2.1 - 05-June-2012
1. Only the base has been changed to momo9. Rest all is same.
Changelog v3.0 - 20-June-2012
1. New Kernel - Not compiled by me Just Ported
2. Added USB Bluetooth Support - Tested
3. Added PS3 Gamepad Support (hid-sony.ko) | Wired | Original - Tested
4. Added USB GPS Support (pl2303.ko and tun.ko) - Untested
5. Added USB Serial Module (cdc-acm.ko) - May help in 3G Dongle Support - Untested
6. Added Circle Battery Mod
7. Added Google Talk
8. Added Novo 7 Tools - Easy Reboot and Reboot Recovery
9. Updated Play Store
10. Fixed Time Zone to India
11. Removed Adrenaline Cpu Control
12. Removed Setup Wizard
13. Removed Google TTS Engine
Download Link1. Reboot to recovery
2. Wipe data/ Factory reset
3. Wipe Cache
4. Wipe dalvik cache in advanced menu
5. Install zip from sd card and locate this zip and flash.
6. Reboot system
How to:-Fun_Series_v1.zip - Fun Series v1
Fun_Series_v2.zip - Fun Series v2
Fun Series v2.1.zip - Fun Series v2.1
Fun Series v3.0.zip- Fun Series v3.0
Credits:--Bluetooth
Insert the Bluetooth Dongle and wait for it to initialize. The led on the dongle will start blinking after successful initialization ( If LED is Stable then plug out and plug in again). After then go to Settings and Start the Bluetooth.
PS3 Gamepad
Connect your PS3 controller via cable to your tablet and Press the PS button on the controller. Check the working of the controller by moving the left Analog Stick.
Disclaimer:-Chainfire for SuperSU
imbawind for Adrenaline Boost and CPU Control
H M Judge for Build.prop tweaks
varun.chitre15 for the right direction
slaid480 for Lag free V3
skynet28 for EXT4 Journaling Disable Mod
bududroid for Beats Audio
ahmish for ICS Hide Bar Mod from Ainol novo 7 advanced ii 4.0.3 ics - Symbianize
shashwat for Sdcard swapping Mod from [Script] Change sdcard to memory card. | Funbook
dsixda for Android Kitchen.
To all who clicked the Thanks button and made me feel motivated.
If someones name is left then i really apologise for that...![]()
